Help Identify Marzocchi Forks + extra pictures
This is a discussion on Help Identify Marzocchi Forks + extra pictures within the Technical forums, part of the Caferacer.net Forums category; Alright so thank you for the massive amount of help with the previous post on racing front end items. I have two sets of 35mm ...
Results 1 to 9 of 9
    Junior Member Crosscreek's Avatar
    Dec 2012
    Boise, Idaho, USA.
    I have two sets of 35mm Marzocchi forks. The one set on the right are the longer 35mm forks that came on the Ducati 350 Scrambler. The forks on the left are ones I am not so sure about. I am pretty sure they are Marzocchi but are shorter and may be for road racing.
    Check out the photos below. Thanks for all the help and opinions good or bad are welcome.
    Here are photos of the frame and engine. Like people have said it might be overkill but in my opinion I think it will be in good fun. I have the original parts that I am restoring as well.
    Dellorto SS1 D and DS Carbs. Using the right D carb. These came off a Moto Guzzi V700.
    Supposedly 1969 Ducati 350 Scrambler (non Desmo).
    I don\'t have a solution but I do admire the problem.
    Jun 2008
    SE MI, USA.
    I'm feeling pangs of jealousy and guilt when I see this, it reminds me of my long neglected Ducati project! Nice score(s).
    -Craig
    could be marzocchi or betor forks. are there any decals or casting marks?
    IIRC the marzocchis were copies of the ceriani front ends, since you have both measure the distance between the axle and the fender mount on both and see how close they are.
    Do you want to sell that unidentified set?
    Member CBclubman's Avatar
    May 2011
    Hull, Yorkshire, United Kingdom.
    Can't answer the fork question, but I have never seen a drum brake that big, Is it 2LS or 4LS? and is it as effective as it looks?
    Edit: my bad, just read your other thread.
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    Those other 2 sets of forks are way better than those junkie Ceriani 35mm's. Send the Ceriani's to me for Christmas.
    www.CreativeCandy.org
    Sep 2012
    It's not a 4LS, they have different venting than that one.
    Dec 2012
    Boise, Idaho, USA.
    Aug 2006
    Portland, Oregon, USA.
    ....or maybe it is.....
    ~Albert Einstein
    I think that is a fontana.
  1. Marzocchi
    By TSwami in forum General
    Last Post: 10-24-2012, 03:53 AM
  2. Marzocchi and Ohlins rebuild kits?
    By Geeto67 in forum General
    Last Post: 01-25-2011, 09:45 AM
  3. extra neutral/gear not engaging
    Last Post: 04-27-2008, 01:21 PM
  4. Anyone have an extra 10 G's around?
    By oldschoolorange in forum Bikes For Sale
    Last Post: 12-18-2007, 12:14 AM
  5. anyone got an extra cb750?
    By bcrawford in forum Wanted
    Last Post: 10-30-2006, 05:59 PM
ducati 350 marzocchi forks
how to identify marzocchi fork
identify marzocchi
marzocchi 35mm forks
marzocchi fork 35-mm parts
marzocchi fork images
marzocchi front fork
moto ss1
www.ceriani motorcycle front fork parts
