1973 cb500/550/592 big bore (k and s switch wiring problems) - Page 2
This is a discussion on 1973 cb500/550/592 big bore (k and s switch wiring problems) within the Technical forums, part of the Caferacer.net Forums category; Sucks that you can only contact K&S through email or FAX. I assume then they don't sell retail and will direct you to a dealer....
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    www.CreativeCandy.org
  2. #12
    Nov 2008
    K&S are dealer only, generally not expensive stuff but not available direct
    500 and 550 are similar enough wiring to swap over, you probably have more than one issue though.
    the newest 550 harness will be at least 34 yrs old, fitting a 500 harness it will be at least 3~4 yrs older, probably not the most sensible thing to do?
    You have all the information you need, your not colour blind are you?
    The switches will have to connect to the correct harness colours, not 'colour to colour' as original, you haven't tried 'everything' or it would be working.
    Get a cheap multi meter ($5.00 or less) and make sure wiring harness is good before going any further (check on ohms for wire continuity)
  3. #13
    Member photoputz83's Avatar
    Aug 2011
    eau claire, wisconsin, USA.
    i did use a multimeter (fluke brand). i did end up testing the entire system. One of the switch leads ended up being mislabled. pulled apart the switch and sorted it out. still going to install the 550 harness but dreading haveing to re-wrap another one. Guess ill just need to bite my tongue and do it anyway.
  1. Wiring an Ignition Switch
    By ZouLou in forum Technical
    Last Post: 08-17-2009, 09:43 AM
  2. 1973 Honda 500, Electrical problems/ cafe
    By Jakker91 in forum Technical
    Last Post: 06-20-2009, 12:20 AM
  3. CB500 Bore Kit
    By ct_racer in forum Wanted
    Last Post: 12-13-2007, 11:47 PM
  4. toggle switch wiring
    By teighlor in forum Technical
    Last Post: 03-14-2007, 09:05 AM
  5. cb500/550 big bore NOS
    By JD in forum Parts For Sale
    Last Post: 10-01-2003, 03:29 PM
1973 cb500 turn signal switch
cb 500 550 wiring problems
cb500 problems
honda cb500 big bore kits
k and s 12-0055 wiring diagram
k&s 12-0055 wiring diagram
k&s motorcycle switchgear 12-0202
k&s start stop switch
k&s switch problems
Tags for this Thread
