Brake/Taillight won't work w headlight on
This is a discussion on Brake/Taillight won't work w headlight on within the Technical forums, part of the Caferacer.net Forums category; Hi, I have a 73' Honda CL350 and I installed an aftermarket taillight. The original taillight has three wires...ground, power and running. The new light ...
Results 1 to 7 of 7
    Junior Member jjackson337's Avatar
    Oct 2012
    Indianapolis, IN, USA.
    Hi, I have a 73' Honda CL350 and I installed an aftermarket taillight. The original taillight has three wires...ground, power and running. The new light has on two wires...power and running (ground by touching frame). The problem with the new light is that the brake light works, but when I turn the headlight on the brake light no longer work and the taillight won't turn on. I tried a different aftermarket taillight and got the same result. I feel light there is a simple solution to this but I can't figure it out. Maybe something to do with the ground. Here is a pic of what I have. There is a youtube video of how to install the bracket and wires here . I have the same wire setup as the one in this video but mine doesn't work. Am having trouble getting an answer from the seller. Please help!
    Nov 2008
    Pretty simple, you wired it wrong so something shorts when you turn on headlight. I'm sure if you leave it on long enough a wire will start smoking so you can see where the problem is
    Run a separate wire for ground
    Oct 2012
    Ok thanks that sounds probable. This is my first bike and I'm not too savy with the electrical side. Where do I connect the ground wire to the bulb?
    Oct 2012
    ok I think I found the issue. If I take the light off of the bracket and and wire it and ground the metal base of the light housing to the frame it works...but not very consistently. Is it possible that the paint on my frame or the paint on the license plate bracket is preventing it from grounding effectively? Should I try to sand some of the paint on the bracket where it touches the bike frame?
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    Absolutely make sure you have a bare metal ground. Or it will bite you at the most inopportune time.
    www.CreativeCandy.org
    Oct 2012
    Is there any reason why mine won't ground at the bottom of the shock?
    Nov 2008
    Remove paint from bracket and run a wire to the frame.
    Swing arm has rubber bushings so your grounding through various moving metal components (drive chain, brake linkage, etc)
    It was probably designed for a rigid frame?
  1. taillight
    By Geeto67 in forum General
    Last Post: 12-16-2011, 02:36 PM
  2. Wiring woes: Part 2 Taillight
    By CafeCrazy in forum Technical
    Last Post: 07-20-2010, 12:34 PM
  3. Wiring a brake switch to the front brake
    By cafe350 in forum Technical
    Last Post: 09-07-2009, 08:46 AM
  4. No more stupid taillight!
    By Chip in forum Project Builds
    Last Post: 01-15-2008, 02:45 PM
  5. maybe this will work
    By joe c in forum Vintage Motorcycle Racing
    Last Post: 10-19-2003, 10:15 PM
aftermarket headlight assembly taillight doesn't work
brake and tail light doesn't work
brake lights won't work when headlights are on
cb350 brake led brake
headlight comes on when brake is pulled 73 honda cb 350
honda tail light wont turn on
motorcycle tail light doesn't work when headlight is on
my right back motorcycle taillight wont work
taillight brake wont work when headlights on
