dead in the water......73 cb500 77 cb550 engine swap - Page 2
This is a discussion on dead in the water......73 cb500 77 cb550 engine swap within the Technical forums, part of the Caferacer.net Forums category; It's too cold to spend 5 minutes with a voltmeter. Maybe the Internet has a voltmeter and can check it for me. The other day ...
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Senior Member gs1327's Avatar
    Apr 2009
    Cleveland, Ohio, USA.
    The other day my bike quit on the way home, it might be out of gas. Is there something else I should check before I open the gas cap and look in the tank?
  2. #12
    Member photoputz83's Avatar
    Aug 2011
    eau claire, wisconsin, USA.
    Quote Originally Posted by gs1327 View Post
    -17 degrees windchill isnt easy to work in especially when you only have partial function of your left hand as it is. besides the screen on my fluke meter kept on fogging up and at that temperature the contrast on the screen is pretty close to zero.
  3. #13
    Aug 2011
    so i ended up taking off the fuse box and checking the connections/solder joints. all were good. removed the headlight bucket and looked for any loose wires and found none. the headlight fuse is showing continuity with the battery positive and the tail light as well. the battery is still holding steady at 13.12-13.20 volts. it seems as if the vast majority of people on here are just posting smart remarks. i never once claimed to be an electrical genius. i asked the question in hopes to be pointed in an area to look so i can better understand different things that could possibly be worng. i figured that if a few people would point in different areas or to different parts i could figure it out. so if you just want to come and post your piss poor egotistical attitude for all to see ....well you are just wasting my time. all i am asking is if anyone knows what areas i should look or start looking.
    Aug 2011
    the main fuse when the ignition is on is showing no continuity and no power to the battery positive. ill try to trace back to the battery to see where the connection is lost.
  6. #15
    Aug 2011
    Are you getting power to the main fuse or just continuity?
    check the ignition switch and also check that the kill switch is hooked up properly. Put a charger on the battery and make sure it has a full charge (when it is cold out and you have a flat battery it destroys it).
    well i ended up pulling the ignition switch off and replacing it. it seems as if the switch that came off the bike finally failed. thanks for pointing me in the right direction!
  7. #16
    Feb 2006
    even a blind squirrel finds a nut now and then...
  8. #17
    Nov 2008
    Quote Originally Posted by photoputz83 View Post
    tail light fell off? the tail light is an axle mount and is still in place.
    Sarcasm is wasted sometimes.
    Basically, the back end looks stupid that short, don't know why anyone ever thought it looked good?
  9. #18
    Quote Originally Posted by crazypj View Post
    PJ,
    It doesn't look any more stupid than lots of stuff on this bike, like the too short rear shocks so the swing arm is at an incorrect angle and the stupid chrome visor on the headlight, not to mention the color scheme.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  10. #19
    Nov 2008
    I could live with the paint, (and probably crash with the shocks )
    If it won't do at least this it's worthless ( the world really does revolve around me )
  11. #20
    Junior Member vonvendetta's Avatar
    Mar 2013
    PLEASE tell me you have a build thread somewhere. I am not the biggest fan of the green but it looks awesome. Getting tired of seeing all the black frame and black tanks. It is great that you went that route for something completely different.
  1. cb550-650 swap
    By joe c in forum Technical
    Last Post: 08-18-2012, 10:36 PM
  2. Water Buffalo / Suzuki GT750 Engine
    By ksmolenski in forum Wanted
    Last Post: 10-21-2009, 07:54 PM
  3. do i have a cb500 or a cb550?
    Last Post: 07-17-2007, 09:45 PM
  4. cb550 vs. cb500
    By benjamin in forum Technical
    Last Post: 11-07-2006, 11:18 PM
  5. CB500 vs. CB550
    By topher in forum Technical
    Last Post: 07-27-2006, 10:29 PM
77 cb 500
cb500 550 engine swap
cb500 engine swap
cb550
cb550 engine mount
cb550 engine swap
don't have electric power on my point in my honda cb 550f
honda cb500 with cb550 motor
motor honda cb 500
Tags for this Thread
