Where do I find a carb rebuild kit?
This is a discussion on Where do I find a carb rebuild kit? within the Technical forums, part of the Caferacer.net Forums category; I am rebuilding my carbs from an '82 Honda Nighthawk and I can't seem to figure out where to get a carb rebuild kit... From ...
Results 1 to 6 of 6
    Junior Member fossum_13's Avatar
    Apr 2013
    Pullman, WA
    I am rebuilding my carbs from an '82 Honda Nighthawk and I can't seem to figure out where to get a carb rebuild kit... From the image I think they are Keihin VB-22G carbs. Anyone got a idea of where to find the kit?
    Thanks
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    www.CreativeCandy.org
    Apr 2013
    Pullman, WA
    Although I hate ebay and you sent me to a 650(I have a 450), but I did look up a cb450sc. I found what looks exactly like my kit.
    Sep 2012
    You didn't say you had a 450, so how was I to know. You can still get you kit there. I know a lot of people bitch about buying on Ebay. I have been dealing there for years and all the large companies products can be found there for good deals. The places you go to to buy parts are probably dealing them on Ebay also and for less money than if you walked in their store.
    Jan 2008
    Southern Finland
    also:
    1. your friendly honda dealer can get you a ton of stuff you might think is not anymore available, for example (these are in cali but ship and the service is good - prices too):
    California Motorcycle ATV Dealer - Honda Kawasaki of Santa Monica - KTM Power Equipment Scooter Watercraft Generator
    2. Rebuild kits (on ebay and elsewhere non honda) are often questionable. many have wrong jets or just otherwise only half the parts fit. Good news is most things inside carbs don't really wear. So teh typical things you want to change are the o-rings that seal float bowl (so they don't leak) , needle / needle valve depending. Potentially other seals or o-rings. Most other things you can just clean.
    -others can and maybe will add to my list of recommended replaceables. But often you can clean a carb without replacing anything.
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    That's usually true that you can reuse most parts except if your carb has an air cut off or accelerator diaphragms. Those always seem to turn into rock solid little pucks.
    http://www.scramblercycle.com
  1. CB450 Carb Rebuild
    By ssheller in forum Project Builds
    Last Post: 06-25-2017, 12:46 AM
  2. carb rebuild
    By cashoes in forum Technical
    Last Post: 02-21-2012, 01:50 PM
  3. CB450 Carb Rebuild
    Last Post: 12-08-2010, 01:25 PM
  4. carb rebuild kits....
    By DougZ in forum Technical
    Last Post: 06-02-2009, 06:06 PM
  5. Replies: 5
    Last Post: 05-20-2008, 04:48 PM
82 honda nighthawk 450 carb kit
can't find carburetor kit
honda nighthawk 450 carb rebuild kit
keihin vb carb parts
keihin vb22
keihin vb22g rebuild kit
rebuilding 82 nighthawk 450 carburetor
vb22g
where do the carb o rings go on honda nighthawk 650
Tags for this Thread
