I have a '68 Trophy 650. The wiring was a mess and I have modernized to a Pazon and Tympanium, a single dual output coil, and a reissue wiring harness.
Since the wiring was incorrect when I started, I have no original reference to make the new connection to the ignition switch and the headlamp switch.
The 2 position ignition switch has 3 blades (2+1)
The headlight switch is a 3 position toggle with 5 blades.
Can someone point me to a diagram or sketch the appropriate blade connections for the two switches (given the electronics)?
Wire colors are helpful, but where each of the connection leads to would be appreciated.
Thanks in advance.
(and if this is not in the correct forum, my apologies)
