Rear Master Cylinder Cups..
This is a discussion on Rear Master Cylinder Cups.. within the Technical forums, part of the Caferacer.net Forums category; Seems that the SR500 and the XS400 use the same rear master.. Yamaha parts stopped supplying this and the rebuild kit .. Kit # 1u4-w0042-50 ...
Results 1 to 2 of 2
    Senior Member Tonnystark's Avatar
    Jun 2012
    , florida, USA.
    Question Rear Master Cylinder Cups..
    Kit # 1u4-w0042-50 (available older interchange number?)
    DIRECT FITAMENT:
    77-79 xs400
    78-79 sr500
    mikessx.COM doesnt supply the kit nor any of the big parts houses I have tryed.. ( may have to start a yami dealer search tomarrow)
    My rear master on the 500 is rebuildable so am looking for a kit or at the least the 2 internal pressure cups..
    The cylinder is stamped 5/8 diam.. one is a typical flat cup, the other having a hole so to be installed midway on to the piston..
    My final question.. any other bike's use the 5/8 diam cylinder that I can pilfer the needed cups?
    It was mentioned on the sr500 and Thumper forums to buy a dodge 5/8 wheel cylinder and plifer the cups...
    78' SR500
    64' YG1S
    15' XT250
    Most newer sportsbikes run 5/8 rear MC's. I don't know if you can swap the seals between them and what you have, but you might be able to just swap the whole MC if you can find one with the same spacing on the mounting holes.
  1. rd master cylinder???
    By midge in forum Wanted
    Last Post: 02-22-2013, 07:42 AM
  2. Master Cylinder
    By Danny Yourd in forum General
    Last Post: 06-18-2011, 12:48 AM
  3. Front and rear master cylinder 1977 Triumph
    By HighonLowSociety in forum Wanted
    Last Post: 05-17-2011, 09:51 PM
  4. Master Cylinder?
    By ZouLou in forum Technical
    Last Post: 07-22-2008, 11:30 PM
  5. Master cylinder....?
    By teighlor in forum Technical
    Last Post: 03-01-2007, 01:44 PM
1977 xs400 rear brake cylinder 1u4-w0042-50
1978 yamaha sr500 rear master cylinder
5/8 master cyl cups
77 xs400 rear master cylinder
cafe racer master cylinder
sr500 rear master cylinder kit
xs400 rear master kit
