Red Rubber Grease..
Red Rubber Grease..
This is a discussion on Red Rubber Grease.. within the Technical forums, part of the Caferacer.net Forums category; No not the tell-tail of deflowered virgins, nor KY... In Europe its called red rubber grease used for rebuilding internally calipers,masters and cylinders.. mainly I ...
Results 1 to 4 of 4
    Senior Member Tonnystark's Avatar
    Jun 2012
    , florida, USA.
    Question Red Rubber Grease..
    mainly I have seen it sold in small tins or plastic tubs (castrol to name one...)
    in the US its not available for sale in the 'red' form... Is ours just a different color?
    While most good kits come with a small supply, I wish to buy a tube locally to have when servicing/maintaining calipers and masters..
    Have read alot of conflicting advice to whats equivelent..
    What's the forum's advice on what to use /recomend ?
    78' SR500
    64' YG1S
    15' XT250
    Nov 2008
    I got some off e-bay, didn't need 50lbs of it, someone is re-packaging into 1~2 oz tins for about $6.00
    Jun 2012
    , florida, USA.
    thanks CRAZYPJ, researched that on ebay also..it was recomended at work to see just what was out there on the shelf whats being used and sold by the auto supply houses and bike shops .. AGS's Sil -Glyde kept up being the #1 recomended product over #2's Permatex green (came to understand green hardens alot quicker with age)..
    The AGS web site's material application information sheet states clearly this can be use to coat and protect INTERNALLY caliper bore's and boot's from moisture , thou it is not not clearly stated on the squeeze tube itself of that specific use.
    (tube states ; ease rebuilding of rubber parts ; o-rings ,grommets and boots ..seals boots against moisture)
    being silicone based and not petrolium it should work fine with rubber parts..
    Sil-glyde so far has the best rep of consistant use on the net and locally ..
    thoughts to yeah or ney?
    78' SR500
    64' YG1S
    15' XT250
    Senior Member Sabre Cafe's Avatar
    Feb 2013
    Pinehurst, North Carolina
    I've used silicone based grease for this application. As you stated, it won't harm rubber like petroleum based grease.
  1. black rubber padding ?
    By Rover in forum Technical
    Last Post: 12-10-2009, 11:55 AM
  2. restoring plastics and rubber
    By ukTony in forum Technical
    Last Post: 11-28-2009, 04:21 PM
  3. old hard rubber
    By burntblacktoast in forum General
    Last Post: 09-04-2008, 08:25 PM
  4. Derbi rubber
    By notNicky888 in forum Vintage Motorcycle Racing
    Last Post: 06-19-2006, 04:30 PM
  5. Derbi rubber
    By notNicky888 in forum Wanted
    Last Post: 06-14-2006, 09:37 PM
buy red rubber grease
castrol rubber grease us where to buy
red rubber castrol grease
red rubber grease
red rubber grease buy
red rubber grease in us
red rubber grease usa
triumph red rubber grease
where to buy red rubber grease
