GS550 Carb Vacuum line issues
This is a discussion on GS550 Carb Vacuum line issues within the Technical forums, part of the Caferacer.net Forums category; I have a GS550 with BS32SS mikuni carbs and I haven't been able to get a real answer from anyone as to why I'm having ...
Results 1 to 5 of 5
    Mr.
    Mr. is offline
    Junior Member Mr.'s Avatar
    Mar 2014
    I have a GS550 with BS32SS mikuni carbs and I haven't been able to get a real answer from anyone as to why I'm having this issue or how to fix but maybe you guys can help here.
    The bike had a leaky vacuum actuated petcock, so I decided to install a manual fuel valve and set the petcock to prime. I blocked the vacuum line that actuated the regular valve.
    Now that I have everything back together, there are two lines that I have been told by some are supposed to go to the ground, to the airbox, to the other carb vent, etc,.
    These lines are pretty peculiar though in a few ways:
    1. the line on the left side of the carbs doesn't seem to do much of anything when blocked
    2. the line on the right side makes the bike idle at around 4000rpm when blocked and slowly bog down and stall when open
    What the hell are these lines for, why do they make this happen, and WHERE DO THEY CONNECT???
    They are the float bowl breather pipes. They should just be routed down towards the swingarm pivot area. Don't block them or connect them to anything else.
    Senior Member goldy's Avatar
    Feb 2013
    Nova Scotia
    How about some pictures?
    “And this you can know – fear the time when Manself will not suffer and die for a concept, for this one quality is the foundation of Manself, and this one quality is man, distinctive in the universe.”
    John Steinbeck
    Mr.
    Mr. is offline
    Mar 2014
    I'll grab some this weekend.
    I'm not a carb expert but it seems like the engine runs immensely better when I have the float bowl breather on the right plugged. It revs really high but doesn't bog when throttled.
    Can anyone explain why this happens? I know it's not my solution but I'm just curious.
    I think I also have a vacuum leak somewhere in the main airbox from incorrect reassembly and this could be causing the problems.
    Blocking the breather is probably changing the fuel levels in the bowls - IE: you've probably got them set wrong.
  1. 82 CB900F Carb issues
    By EofA in forum Technical
    Last Post: 04-22-2012, 08:32 PM
  2. CB360 carb sync vacuum adapters
    By crazypj in forum Parts For Sale
    Last Post: 11-14-2011, 06:29 PM
  3. carb repair - fuel line elbow
    By sdurand76 in forum Technical
    Last Post: 04-06-2011, 08:52 PM
  4. Coil Spring for Vacuum Piston in Carb
    By mega4ce in forum General
    Last Post: 03-23-2011, 07:55 PM
  5. Carb Issues? Please help!
    By ZouLou in forum Technical
    Last Post: 03-15-2009, 12:43 PM
forum gs55 petcock vacuum
gs 550 carbs
gs550 carb lines
gs550 carb problems
gs550 carb settings
gs550 carb tuning
gs550 carb where do you install the vacuum line
how to instal gs550 airbox
right carb vacuum line gs550
Tags for this Thread
