Neck bearing problems.
This is a discussion on Neck bearing problems. within the Technical forums, part of the Caferacer.net Forums category; Trying to get the buell thunderbolt front end on the 79 xs11 frame. Buell stem OD is 25.4mm or 1 inch. Xs neck top race ...
Results 1 to 3 of 3
    Senior Member Joep7's Avatar
    Sep 2011
    West MI, USA.
    Xs neck top race mount ID is 47mm, lower is 55mm, widths are 11mm and 16mm respectively.
    so my top bearing needs to be
    25.4/47/11
    bottom
    25.4/55/16
    problem is that neither allballsracing or McMaster carries anything in that size.
    im thinking my option may be to either turn the stem down or machine a bushing that fits in the neck....or both.
    Any other thoughts?
    Sep 2011
    West MI, USA.
    With hillsy's help over at DTT I think the plan is make two bushings that gets my stem OD to 30mm and then getting a 30/47/12 and 30/55/17 bearing set. Should be easy enough to make and I can machine a recess in the stem with a 1mm lip to press seat the bushing on.
    No problem
  1. look what came to our neck of woods
    By kerosene in forum General
    Last Post: 04-04-2012, 10:36 AM
  2. Neck bearings are assholes
    Last Post: 09-27-2011, 06:51 PM
  3. Replies: 2
    Last Post: 08-18-2011, 08:44 AM
  4. Steering neck bearing seal conundrum
    By KeninIowa in forum Technical
    Last Post: 12-26-2010, 11:38 AM
  5. CB360 Frame or neck
    By 7zark7 in forum Wanted
    Last Post: 04-01-2010, 03:47 PM
xb buell neck stem 1 inch?
