Rust Removal Methods for Forks??
This is a discussion on Rust Removal Methods for Forks?? within the Technical forums, part of the Caferacer.net Forums category; Just curious if anyone had a good method for removing rust divots on the front forks, specifically the upper tube. I am a little concerned ...
Results 1 to 10 of 10
    Senior Member The Chief's Avatar
    Feb 2014
    Watertown, NY
    Question Rust Removal Methods for Forks??
    Just curious if anyone had a good method for removing rust divots on the front forks, specifically the upper tube. I am a little concerned with taking anything abrasive to the fork tube and possibly damaging the tube. Any prove methods would be great, thanks fellas.
    He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.-Thomas Jefferson
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    Fine wire wool, and Solvo Autosol can work well. They can be hard chromed, but it's not cheap. I had a pair of stanchions re-chromed a few months ago, it cost £170.
    Member jackattack's Avatar
    Mar 2014
    Cincinnati
    Aluminum foil and coca-cola.
    Jul 2008
    Kenosha, WI, USA.
    Depending on the pitting, there may be some chrome lifting from the substrate. I used a fine whetstone to hand-grind the sharp edges back flush. You can feel the drag on the stone as it catches the edge, then it smooths out after a few strokes. I sprayed some Must-for-Rust (phosphoric acid, mostly) to get down in the pit and hopefully stop any further corrosion for a while. As a final experimental step, I filled the pits with metal epoxy and sanded that back down. Right now I can run a fingernail over the pits and it doesn't catch, so hopefully (fingers crossed) it won't trash my new fork seals too quickly.
    It's temporary at best, really. I've seen that Forking by Frank is closing down, anyone have a new solution yet?
    Dictated but not read.
    Feb 2014
    Watertown, NY
    Where can I find Solvo and must for rust? I have never heard of those. I havent seen either in Lowes or autozone. Walmart?
    Oct 2013
    Colchester, England
    I just looked on ebay.com, and solvo is available for $8.55
    Senior Member Mark Burton's Avatar
    Jan 2014
    Midlands UK
    My Mrs has discovered that Solvo works well on her copper kettle, so I have to hide my polishing stuff now!
    Oct 2013
    Colchester, England
    My Mrs would have me polishing the kettle.
    Senior Member nicebikemate's Avatar
    Oct 2013
    Oxford, England
    You're both lucky, my mrs would try to chuck the kettle out and buy a new one!
    Ignorance Is Bliss
    Jan 2014
    Midlands UK
    .....Its a big old ornamental thing. She put it on my bench in the workshop with a note saying "clean me" on it. I sent it back with a note of reply. A day later, I see it shining in all its glory to find my treasured tube of Solvol squeezed from the middle with its top cross threaded.
    Rubbing lightly pitted chrome with tin foil works really well though. Wont be great for the seals on hard chromed fork stanchions, but a quick fix or bodge to brighten something up.
  1. Rust Removal by Reverse Electrolysis
    By Derby in forum General
    Last Post: 04-05-2012, 06:46 AM
  2. Rust removal by dipping??
    By JackC in forum Technical
    Last Post: 01-11-2011, 11:13 PM
  3. Rust removal
    By UngaWunga in forum General
    Last Post: 12-02-2010, 07:07 AM
  4. (Got Any) Rust Removal Tips
    By Tigertree in forum Technical
    Last Post: 10-14-2009, 03:21 PM
  5. Rust Removal
    By jbranson in forum Technical
    Last Post: 12-17-2005, 04:50 PM
electrolysis fork tube
