Upgrading Rear End to a Disc Brake
This is a discussion on Upgrading Rear End to a Disc Brake within the Technical forums, part of the Caferacer.net Forums category; curious as to whether anyone knows which swingarms/rear ends would swap with a CB500T to upgrade it to a disc brake...gracias....
Results 1 to 5 of 5
    Member KrooklynCB's Avatar
    Jul 2006
    Krooklyn, New York, USA.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    ive always wanted to do that with my 550.
    hmmmm....
    Mar 2002
    , , Turkey.
    hmmmm....
    As strictly a bolt on there are none that I know of (but then again I don't really have much expirence with a cb500t).
    The two popular wheels/rear ends to use for disc brake conversions in the 1970s were 1975-76 cb750F and 77-79 GS750 (spoke rims - the GS also came with mags and the cb750F had mags in 77-78). These are still antiquated discs by modern standards but their overall rim width probably means they will fit inside your frame. The main issues you will need to deal with are chain line, wheel spacing, and axle diameter. There is a lot of custom stuff involved in this so make friends with a welder and a machinist.
    As long as you are going to to massive modifications you might as well upgrade to modern discs and wheels. I personally don't think any 70s disc is gonna stop as well as your drum rear so if weight is the only motivating factor for the swap I'd look at an early ex500 wheel. Kinda modern three spoke mags, lighter, and a much better drum. Once again you will have to deal with chain line, wheel spacing, and axle diameter. Anything more modern and the rim is likely to be way to big.
    go to the bike salvage yard with a tape measurer and explore. That is how I put fzr wheels and suspension on my h1
  1. need a rear hub for spokes w/ disc
    By roccitycafe in forum General
    Last Post: 12-01-2011, 06:32 PM
  2. TZ250j rear hub, brake hanger, disc and axle
    By snorkelfork in forum Parts For Sale
    Last Post: 12-31-2010, 08:48 PM
  3. Converting front disc brake hub to rear wheel?
    By borzwazie in forum Technical
    Last Post: 03-22-2008, 12:14 AM
  4. upgrading front brakes on mechanical disc
    By speedy81304 in forum Technical
    Last Post: 01-18-2008, 04:59 PM
  5. Disc Brake Help
    By 350Four in forum Technical
    Last Post: 02-12-2007, 09:32 AM
