Xr200 front wheel sprocket mount
This is a discussion on Xr200 front wheel sprocket mount within the Technical forums, part of the Caferacer.net Forums category; I have a project where I need to chain drive a 21" wheel. Low horsepower type thing. I don't really wanna lace up a 21" ...
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By 44dwarf
Thread: Xr200 front wheel sprocket mount
    Senior Member raven's Avatar
    Jan 2009
    milledgeville, ga, USA.
    I have a project where I need to chain drive a 21" wheel. Low horsepower type thing. I don't really wanna lace up a 21" rim to a rear hub because its a low buck type thing. So I am proposing drilling a sprocket to fit the studs that the spoke flange on about a 1980 model wheel attaches with. These are four M6 studs. I do not have a wheel on hand yet, but does anyone see a glaring issue with this?
    Bike:
    Buell X1
    Honda S90 (box of parts)
    Honda CB750C (runs)
    Senior Member 8ball's Avatar
    Nov 2012
    East TN
    Four M6 studs doesn't sound substantial enough, to me. What does the spoke flange do in the original config? What stresses would it see? Without a cush drive, especially, I would think that those small studs would just rip out ..even with as low as 10 HP. If this is for a motorcycle, look at the original application. Usually it would have 6 M8 studs, or better. With a larger wheel diameter, you will have a greater moment arm reacting against the drive sprocket studs.
    My GS550 Build Thread
    Senior Member 44dwarf's Avatar
    Sep 2010
    North Central, Mass, USA.
    Use the later disk brake wheel and put sprocket on same bolt pattern as the disk?
    kerosene likes this.
    USCRA #944
    WVRC #44
    www.wvrclub.com
    Jan 2009
    I will have to get the wheel in hand and take a look. Alot depends if i can add studs or reinforce it in some way. I may end up lacing a wheel after all.
    The flange originally carried radial load from the spokes and I would estimate 50% of the torque load from braking (as half the spokes attach to it). Braking load is different from the "pounding" load of an engine however as its primarily a single direction torque when the brake is applied. With engine braking and power pulses I could see where the M6 studs could be quickly fatigued if they are not ripped from the hub. Thanks for the input.
    I would go w/ the disc but I want the drum :/
    Bike:
    Buell X1
    Honda CB750C (runs)
    Quote Originally Posted by raven View Post
    You could do what the HD chopper guys do and use one of those sprockets that doubles as a disc rotor.
    Jan 2009
    Well. What this is for is a semi sort of pannier tank AJS replica. I'm thinking lacing to a more suitable hub will be best.
    Bike:
    Buell X1
    Honda CB750C (runs)
  1. how to mount a cb750 front brake without a fender
    By banta071 in forum Technical
    Last Post: 09-24-2013, 09:35 PM
  2. 1979 CB750F REAR WHEEL SPROCKET
    By medic07 in forum Technical
    Last Post: 06-01-2011, 07:39 AM
  3. Need Help FRONT WHEEL
    By Motos in forum Technical
    Last Post: 02-17-2011, 04:38 PM
  4. Front Sprocket
    By 350Four in forum Technical
    Last Post: 11-16-2008, 06:04 PM
  5. RD350 Front wheel
    By craig641 in forum Wanted
    Last Post: 12-04-2007, 08:52 AM
