destructive testing with bronze
This is a discussion on destructive testing with bronze within the Technical forums, part of the Caferacer.net Forums category; having some thoughts on frame building lately, going over methods, probably will use crmo tubing, looks like bronze fillet brazing is the way to go, ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Like Tree4Likes
Thread: destructive testing with bronze
    Sep 2008
    Rochester, New York, USA.
    having some thoughts on frame building lately, going over methods, probably will use crmo tubing, looks like bronze fillet brazing is the way to go, doesn't overheat the base metal and isn't hard as nuts, this test piece was bent back and forth until it broke, you can tell by the distortion of the tube that the haz wasn't made brittle by the process like tig does
Size:  3.11 MBName:  IMG_1491.JPG
    Senior Member CAPTAIN AWESOME's Avatar
    Aug 2008
    Bentonville, AR, USA.
    I'm curious as to what you are building?
    I've got a couple frames I would like to braze weld and have been getting the most basic info from Eurospares. Any tips, tricks, etc. to give to a new guy? I've torch welded before, but it's been quite some time since I've had practice. Usually just pull out the mig for tabs and brackets, but would rather braze.
    Senior Member raven's Avatar
    Jan 2009
    milledgeville, ga, USA.
    When I have done brazed joints on things, it always takes me atleast twice as long because I had precision fit up driven into my head. With MIG and I suppose TIG (I have not done much of that...) you can deal with imperfections in the fitup. Brazing is strongest when its a capillary action between the parts. This goes for bronze brazing as well as plain old tractor supply brazing rods as well as silver soldering bits together. You have demonstrated that bronze brazing, when done properly is way way more than adequate for pretty much any bike frame use. And its pretty :P
    Bike:
    Buell X1
    Honda S90 (box of parts)
    Honda CB750C (runs)
    Makes perfect sense. Your weld material melts at a far lower temperature then your base material.
    & the strength of the weld is dependant on adhesion, instead of melt and penetration.
    Sep 2008
    Quote Originally Posted by CAPTAIN AWESOME View Post
    I'll try to put together a video, I think it comes down to flux application, bronze selection, and heat
    and yes, the joints do like to be fit very very well, I coped the tube then came in with a file to get the joint perfect, it's definitely not a production friendly process
    Aug 2008
    That would be cool. Are you tacking then jumping around to reduce distortion or was this just a "test" kinda thing?
    Sep 2008
    the tube is tacked 4 places, then the braze is just run around the tube, the bronze braze doesn't really pull like a weld does, the temperature only gets to about 16-1700, as opposed to 2500 or more for a weld, so once its tacked, it really doesn't move. really nice feature for frame building as it doesn't add a lot of stresses into a frame built on a jig
    Aug 2008
    Also, why Chromoly? The heat treating sounds like a pain, but it could just be my complete ignorance to the subject. I'm also curious how significant the weight difference would be to mild steel.
    You could borrow from ancient bicycle technology "lugged steel frame construction" for more ideas.
    Lugged steel frame construction - Wikipedia, the free encyclopedia
    Aug 2008
    Just for clarification, that is brazing, and not braze/bronze welding. Am I correct? Capillary action draws into filler rod into the lug. Roc is braze fillet welding.
  1. Testing Coils - for a no good dummy.
    By nixoid in forum Technical
    Last Post: 07-09-2012, 06:37 AM
  2. 74 cb450 torsion bars testing...
    By SeeBee450 in forum Technical
    Last Post: 03-22-2012, 12:10 AM
  3. RD400 crank case pressure testing
    By nic579 in forum Technical
    Last Post: 05-07-2011, 09:15 PM
  4. Testing Coils - for a no good dummy.
    Last Post: 10-14-2010, 07:26 AM
  5. open testing days at NHMS
    By dreamqueen in forum Vintage Motorcycle Racing
    Last Post: 08-10-2010, 09:16 AM
bronze welding motorcycle frames
tig bronze welding
