1970 CL100 Cafe Project - Bore Information? - Page 3
This is a discussion on 1970 CL100 Cafe Project - Bore Information? within the Technical forums, part of the Caferacer.net Forums category; Buy a Skyteam ACE 125 tank and seat. I think the only thing you will learn is bikes cost real money, and hotting up a ...
Results 21 to 30 of 32
Like Tree3Likes
Thread: 1970 CL100 Cafe Project - Bore Information?
  1. #21
    Banned Witworth's Avatar
    May 2014
    West
    Name:  CB125N cafe $_57.jpg
    I think the only thing you will learn is bikes cost real money, and hotting up a bike is beyond you meagre skills.
    Danger, is my business."
  2. #22
    Junior Member CNorthness's Avatar
    Feb 2015
    Albuquerque, New Mexico
    That's exactly the point. I won't learn unless I try this sort of thing. I bought the bike for next to nothing and have plenty of room to lose out. I'm paying for the learning experience. Whatever time and money I throw at this will be for learning's sake. Thank you for all the technical support. I believe a 125 from the same era uses the same mounts and all, correct? Just as an afterthought for an option B, given I muck this up horribly.
  3. #23
    Feb 2015
    But! As far as style, I don't know if this is cafe sacrilege, but I plan on fabricating a hoop for the rear of the bike and welding it on to replace the forked back end, then building myself a long, flat brat seat.
    May 2014
    West
    Quote Originally Posted by CNorthness View Post
    Well you don't need a long flat brat seat on a bike that puts out about 9 BHP.
    Unless you plan on having a relationship with a blow up woman... Who you gonna haul?
    monkey likes this.
  6. #25
    May 2014
    West
    The 125 motor fits straight in.
  7. #26
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    There is no cafe racer style.
    you are talking about choppers.
    I am Derby\'s Bitch
  8. #27
    Jan 2008
    Southern Finland
    The best hot options are:
    XL185 (actually 180cc) or XR200 (actually 190cc) crank and the cylinder+head from either. The cases need machining which means splitting. Its not a huge deal as its a simple bike. They can be further bored to true 200cc or even over. I think the 190 would be plenty.
    Then get roller bearing cam (webcamshaft I think) and titanium valvetrain components. You naturally need the camchain with tensioner from XL185/xr200. Naturally carb (there is a mikuni pumper version of the 28 that might work perfectly with a hot engine. Naturally after proper tuning). Oh and the newer heads are for CDI ignition, not points so there is that. The stators are different. othrwise you could use cb360 stator to go 12V with better output but the CDI is an issue. Maybe you'll just design a transistor system of your own...
    So it all can be done. And you will get 18+ hp, maybe even 20+ if everything is done well and right. It will cost you maybe $1000-$1500. That right there is your answer. If you are not doing it because of the tinkering and challenge itself its absolutely pointless. No sense at all.
    You could fit a full (early) xr200 motor (do they have light coil, not sure) or chinese pushrod honda knockoff engine. Its still a lot of work for questionable goal.
  9. #28
    Jan 2008
    Southern Finland
    you are failing in the 1st lesson my man. I mean this kindly. You are failing to hear what people are saying. Get the bike working as well sock 1st is the smartest thing to do. If that is not enough after a few hundred miles (you will notice that the suspension and frame are also scooteresque) sell it (if you kept it stock, its worth decent money well sorted out) and buy something else.
  10. #29
    Dec 2005
    Albany NY
    I own, and have owned a few of these Honda singles.
    Been down the "make it less slow" and all that before. Personally I now just prefer them stock. I view them as best in this role.
    BUT completely understand the desire to learn and just generally make something out of random parts. In that respect these bikes are great for that.
    They are small, parts are easy to get and cheap. Honda made millions of these things. I would rather see someone learn to mix and match junk on one of these then blow apart a 4 cylinder and drown.
    The idea should always be fun.
    But dont brush off what people are saying by using the cop out " ill learn it myself". If that was the case then you would not be on the internet seeking out help, you would be in the garage doing something. So take some advice and you will have a leg up.
    That motor that kerosene was talking about might be something fun for you to build.
    What I would do is service the shit out of the bike you have and ride the wheels off it. While doing that find a spare motor and build it up.
    You will then be wrenching on a fun project AND riding the bike. Then one weekend swap the motors. Another thing you gain with this is a good baseline.
    the 18hp of the new motor will still feel slow, unless you have been riding around for a while with 11hp.....
    And we do still need to talk about how bad these bikes are at "cafe racer" builds.
    The motors HATE to run with short pipes or pods. Rearsets are hard to mount. ect ect
    Play to a bikes strengths. "racing" aint it.
    Here is mine
    Bought it with 1100 miles from the original owner's family. I use it to run out for beer (that rack is epic), pick up parts and just general running around.
    It is a blast. Have run it out on the beach, and taken it though the woods. Just a nice bike to have around.
    monkey likes this.
    I am Derby\'s Bitch
  11. #30
    Feb 2015
    Thanks, Jaguar. Likely the best post on the thread thus far. Over the last few days I think I've come to the same conclusion. I'm going to inspect the cylinder walls for any damage, and if all is well, put it back together and build something to swap. Yes, everyone: Build another gutless motor to make less-slow (very well said, Jaguar). Again, money can buy a racer or a buildable platform. But this is all for knowledge.
    Brat seat because I think they look bad ass.
    I'm not raking any forks or trying to find any chrome, chainlink ape hangers; So nah. Not choppers.
    But! I'm fond of the hot motor described by kerosene. Any other useful technical suggestions?
  1. 1971 CL100 - beginning cafe racer project- shocks, forks, electrical?
    By juanitojojo in forum NEW MEMBERS READ HERE!
    Last Post: 11-28-2014, 10:47 AM
  2. 1972 Honda CL100 Cafe Racer Project
    By wasp in forum Project Builds
    Last Post: 08-31-2012, 02:07 AM
  3. 1970 CL350 project
    By Braydon in forum Project Builds
    Last Post: 07-26-2012, 08:12 PM
  4. 1970 cl350 cafe project
    By ejohnston in forum Project Builds
    Last Post: 09-26-2011, 11:20 PM
  5. 1970 Honda CB 350 Project
    By mitchellsk in forum Project Builds
    Last Post: 10-12-2008, 08:57 PM
ace cafe 125
cl100 18hp motor
cl100 cafe
cl100 cafe racer
cl100 cafe seat
honda cl100 cafe
honda cl100 cafe racer
honda cl100 cc engine hp modifications and upgrades
xr200 head swap cl100
Tags for this Thread
