'75 360T Swing arm
'75 360T Swing arm
This is a discussion on '75 360T Swing arm within the Technical forums, part of the Caferacer.net Forums category; Would it be possible to change the swingarm on my bike in order to put a larger back rim/tire on? also, i would like to ...
Results 1 to 6 of 6
    camaro97z's Avatar
    Aug 2006
    '75 360T Swing arm
    Would it be possible to change the swingarm on my bike in order to put a larger back rim/tire on? also, i would like to relocate the foot pegs to change the riding position. Is there a standard way of doing that? do i just weld a bracket to the new location?
    I don't think you need to change the swingarm in order to run a 130 tire, so I wouldn't bother. Unless, you wanted to go with somethin like an alluminum one to look cool. In that case I have kinda looked on ebay at CR125 swingarms and they might be able to be made to work.
    As far as rearets go, get out the search function on this board case they have been discussed plenty of times and there are lots of good ideas already posted.
    AHRMA 412
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    If SA length is the issue (and almost all the CB's handle a bit better with a longer swingarm) then just cut it and add a couple of inches.
    camaro97z's Avatar
    Aug 2006
    What about an aluminum swingarm to save weight? would it be affective?
    Feb 2004
    Yeah it would be effective....might not save much weight really...but would probably be much stiffer for about the same weight.
    Might be some work to adapt a modernish Aluminum swingarm to an older bike though. Would look very trick. Probably worth a shot trying to find something close. Only problem with aluminum would be any modifications needed (welding) might be a bit trickier.
    Check this out, it gives dimensions and everything. I think it might be close to a bolt up operation.
    http://cgi.ebay.com/ebaymotors/90-Ho...QQcmdZViewItem
    AHRMA 412
  1. 360t cam profile
    Last Post: 01-26-2013, 08:02 PM
  2. '74 CB 360T
    By ReidB in forum Technical
    Last Post: 04-04-2011, 01:10 PM
  3. New Guy With a 360T
    By B40dash8k5h in forum General
    Last Post: 03-03-2011, 11:10 PM
  4. My 360T Cafe
    By DirtKurt in forum Project Builds
    Last Post: 02-28-2009, 11:30 AM
  5. CB/CL 360T Engine
    By Chikor in forum Wanted
    Last Post: 06-08-2007, 12:58 PM
