Scored some old school Performance Machine discs for CB750
This is a discussion on Scored some old school Performance Machine discs for CB750 within the Technical forums, part of the Caferacer.net Forums category; At least that is what we think they are. I haven't found a name on them yet. Got 2 front discs and a rear on ...
Results 1 to 10 of 16
    Senior Member parkwood60's Avatar
    Jun 2010
    Van Nuys, CA, USA.
    At least that is what we think they are. I haven't found a name on them yet. Got 2 front discs and a rear on a set of Comstar wheels. Obviously they are not made of stainless
    Whitworth - The whole Western World economy runs on total lies and BS: I'm a part of the action.
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Very cool!
    I am Derby\'s Bitch
    Feb 2009
    Fort Knox, Kentucky
    whats going on with the holes on the disc on the bottom? it looks like they were drilled partially over the edge of the disc or that the disc was worn down on the outside to expose the holes... is there a reason behind this?
    Quote Originally Posted by CaTacL1sm View Post
    At a guess I would say someone has machined down the outside of the disc after it was drilled to suit whatever fork / caliper combo.
    Banned Witworth's Avatar
    May 2014
    West
    They often do it to reduce weight or maybe even to increase the surface area for air cooling. It even might assist dirt being flung off on dirt bike discs. Some brands of current aftermarket discs are like that. The pads don't run right out there, so it's not a braking function concern.
    Danger, is my business."
    Feb 2009
    Fort Knox, Kentucky
    that makes sense... however what impact, in conjunction with the drilled holes, would this have on the structural stability of the disc? it seems you're greatly multiplying the chances for cracks and fractures to occur.
    May 2014
    West
    If slots and holes were a serious stress riser in discs, the factories wouldn't do it. They are not an issue.
    Jun 2010
    Van Nuys, CA, USA.
    These may even have have the hole cast in, like real race cars. I haven't done much research on them yet. A friend had a similar set market PM
    If you're talking about the outer semi-circled "holes" which are there as a result of the disc being machined down, then they shouldn't pose a risk of cracking the disc.
    In fact, you can pretty much cut any shape hole into a disc as long as the corners are radius-ed (IE: no sharp corners / edges).
    Quote Originally Posted by Witworth View Post
    I have seen failures on racebikes with home drilled discs, but then again I have actually built and maintained and raced race bikes.
    Here is what 15 seconds on the Google showed:
    Looks like the holes might be stress risers after all.
    I also know why brake discs are drilled, not just some speculation on the possible reasons.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  1. SOHC cb750 high performance used pistons for sale
    By Geeto67 in forum Parts For Sale
    Last Post: 04-06-2016, 05:03 AM
  2. pre 89 rs 125 discs
    By monkey in forum Wanted
    Last Post: 12-27-2007, 08:19 PM
  3. performance clutch for k2 cb750
    By pampadori in forum General
    Last Post: 11-17-2007, 11:03 AM
  4. Supertrapp discs ? for Johnny B. ?
    Last Post: 06-19-2007, 08:31 PM
