CB750 Nighthawk Engine Questions - Page 2
This is a discussion on CB750 Nighthawk Engine Questions within the Technical forums, part of the Caferacer.net Forums category; See that big electrical lead coming out of the back of the motor? That's the +ve for the starter motor. Hook that up the +ve ...
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    See that big electrical lead coming out of the back of the motor? That's the +ve for the starter motor. Hook that up the +ve of a battery and then just touch the -ve to the engine body (IE: ground). The starter will then engage.
    Take the spark plugs out before you try this.
  2. #12
    … and since it won't be a fused circuit, make sure you don't over heat either the starter motor or the battery. Starter motors can burn out and batteries can explode.
  3. #13
    Starter motors aren't on fused circuits - they use a solenoid.
    But yes - you will have a lot of current going through the circuit so don't run the starter for more than a few seconds at a time.
    … was only attempting to stress the most extreme scenario possible dangers that could arise in the simplest terms. Storage batteries are not to be trifled with and chances are the battery he has handy is one out of a car or truck. If for instance you drop a spanner across the terminals of a decent sized truck battery, (live short) really bad things will happen very quickly.
  6. #15
    Junior Member UniHalf's Avatar
    Feb 2016
    Amish Country, OH
    Awesome. You guys are alright.
  1. CB750 Nighthawk 1998 Build
    By Coxinator in forum Project Builds
    Last Post: 01-26-2017, 11:45 PM
  2. CB750 Nighthawk Project
    By benjaminlester in forum Project Builds
    Last Post: 03-24-2016, 10:26 PM
  3. Honda CB750 Nighthawk
    By Jakesimmons815 in forum Bikes For Sale
    Last Post: 02-10-2014, 12:56 PM
  4. nighthawk engine in cb350?
    By TheGreg in forum Technical
    Last Post: 10-24-2010, 12:23 AM
  5. cb750 nighthawk 93 model worth 300 bucks?
    By coreyjdl in forum General
    Last Post: 01-22-2010, 11:12 AM
equities
mgmt
sanding
Tags for this Thread
