1982 Honda VF 750S Stop and Taillight Box.
This is a discussion on 1982 Honda VF 750S Stop and Taillight Box. within the Technical forums, part of the Caferacer.net Forums category; Hi, first time poster here. Im having a go at building my first cafe racer out of a 82 VF 750. When i was stripping ...
Results 1 to 6 of 6
    Junior Member Vonremus's Avatar
    Apr 2016
    Billesholm, Sweden
    Hi, first time poster here. Im having a go at building my first cafe racer out of a 82 VF 750. When i was stripping it down i noticed the box in the back for my taillight. It sits in a dumb place and im planning on replacing the stock rear lights.
    My question is, do i need the Stop and Taillight Box or i can feed the new taillight directly without it? Im really crap with the electrical part of building and plan to learn as i go.
    Best regards Tony
    If the wiring diagram I found applies to your bike, there is more than one control box, so the simple answer is yes, unless you plan to rewire the entire motorcycle from scratch and it doesn't really sound like you are up to that task you are better off keeping it.
    Jul 2015
    Ontario Canada
    Yep what Trials said pretty much. When your crap at electrical don't do electrical. Of coarse there is always option 2 $$$$$$$$$$$$$$$.
    Apr 2016
    Billesholm, Sweden
    Ty for your input. Im crap at electrical, but the idea is to suck a little less after this build so ill do as much as i dare and when i screw up ill come here and pick your brains
    Fair enough: so just incase you are wondering what the black box is for, it's mostly to control the warning light on your instrument cluster that tells you when your tail lights have burned out.
    Apr 2016
    Billesholm, Sweden
    Oh, sweet! That was my next question. Then i think ill get rid of it since i wont be using stock instruments. Most of the electrical stuff ill do is just that, removing stuff i wont be using that used to be in the instrument cluster. Ill keep everything needed for safety, like lights, turnsignal and speedo.
    Thanks alot for the info.
  1. Guzzi 750S Replica Build
    By hahnda in forum Project Builds
    Last Post: 04-04-2016, 11:50 AM
  2. 1982 Honda GL500
    By Dlgunter1 in forum Project Builds
    Last Post: 09-02-2015, 03:01 PM
  3. 1982 honda nighthawk
    By aallgire in forum Technical
    Last Post: 07-14-2015, 09:07 PM
  4. Looking for ign coil for 1982 Honda CM450A
    By John Westcott in forum Technical
    Last Post: 12-09-2012, 08:00 PM
  5. 74 750s
    By Jason Lednum in forum General
    Last Post: 03-01-2009, 12:36 AM
