Alternate swing arms for CB450/500T?
This is a discussion on Alternate swing arms for CB450/500T? within the Technical forums, part of the Caferacer.net Forums category; I'm getting into building my '75 CB500t finally (same chassis for all intents as a CB450) and I'm looking for a beefier swing arm, something ...
Results 1 to 7 of 7
    Aug 2006
    Portland, Oregon, USA.
    I'm getting into building my '75 CB500t finally (same chassis for all intents as a CB450) and I'm looking for a beefier swing arm, something a bit more rigid than the floppy thing it currently has.
    If that doesn't pan out I'll be welding on a loop brace...anyone done anything like that?
    ~Albert Einstein
    Senior Member Camelhairy's Avatar
    Sep 2005
    Chester, NH, USA.
    We made rectangular tube SA at Yetmans back in the sixties. Don't remember how many were made.
    FC
    Aug 2006
    Sounds like what I'll need. Was hoping to wimp out and not weld one up myself......dosn't sound like that's gonna fly...
    Senior Member robertob's Avatar
    Aug 2006
    Long Beach, Ca, USA.
    CB750f DOHC might work. At a glance it looks compatible but you will need to do your own homework. Also Suzuki GS1000 (I think, maybe GS750) are aluminum and even longer than CB750F - the CB750F guys use them as a swap.
    Get out your measuring tape!
    Aug 2006
    GS1100 - box section aluminum and same front width as CB750F DOHC.
    Aug 2006
    ... and after some more research I don't think they will work - 9.5" wide at the mount versus 8" (CB450). Oh well, it was a nice thought.
    Aug 2006
    Hmm....I'm not one to give up too easily.....I like the idea of an aluminum box section. I'm not above finding a viable donor piece and hacking and rewelding it. T'would be lovely to find something compatible directly but I'll not count in it.
    I'll be running a set of Konis with adjustable damping and threaded spring jacks I am machining myself. Should be the bee's knees!
  1. CB450/500T stock cam specs?
    By Swagger in forum General
    Last Post: 04-21-2010, 12:19 PM
  2. Need a cb450 or 500t frame with title
    By Swagger in forum Parts For Sale
    Last Post: 02-11-2010, 11:50 PM
  3. Replies: 2
    Last Post: 12-16-2008, 09:14 PM
  4. Wanted: CB450/500T headers
    By borzwazie in forum Wanted
    Last Post: 05-31-2007, 08:28 PM
  5. CB450/500T NOS Ringset
    By KrooklynCB in forum Parts For Sale
    Last Post: 03-10-2007, 09:16 PM
cb450 swingarm swap
cb450 swingarm upgrade
longer cb450 swingarm
