identify a hub CB77 ? front ? rear ?
This is a discussion on identify a hub CB77 ? front ? rear ? within the Technical forums, part of the Caferacer.net Forums category; Anyone know for sure what this 36 spoke hub is from ? Mike...
Results 1 to 10 of 11
    pofflebot's Avatar
    Apr 2007
    Mike
    Senior Member mikeo's Avatar
    May 2002
    Lockport, NY, USA.
    Looks like a rear for a CB77 or 72.
    Mike O.
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    It's the front hub from a CB/CL77 and a REAR backing plate from CB/CL77.
    The large stay lug on the backing plate identifies it as a rear part (the early 305 "dreams" front brakes that had such a lug were single leading shoe). The lack of sprocket mount identifies the hub as a front hub....it's a mismatched set I think.
    PS. Also note that the main brake arm is shorter than it should be for a front brake. The CB/CL77...had different length main brake arms on the front and rear...with the front being about 10mm longer than the rear. Longer front style arm is seen here:
    http://www.jrbranson.com/showandtell.htm
    Second photo down...right hand side.
    Edited by - jbranson on Apr 18 2007 3:29:02 PM
    May 2002
    Lockport, NY, USA.
    Yeah I think Branson's right. I didn't scroll over to look at the other photos when I first looked at it so I didn't see the lack of sprocket lugs.
    Mike O.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    we actually have a brake at the shop no one can identify. ill see if i can get a pic of it. its a honda brake, but really weird. and 90% of the stuff we have is either 350, 450, 305, or 250. so we were all stumped.
    also, i tried to order some 10x1.5 jam nuts from bolt depot. they didnt have them, so they gave me the name of a place here in baltimore. (everyone has been telling me to go there, tex included) its called maryland metrics. they do all british and metric stuff as well as a bunch of other stuff. bearings, seals, etc etc etc. old racecar guys. i dont know the website, you can order online, but i do know if you go to spacely-sprockets.com, or cogswell-cogs.com, they own both of those domains and you can find them there.
    they are one of those old school types of places that has literally everything you can imagine.
    also, if anyone is looking for some datsun mags, 12x5 and 12x5.5, they have a set thats been sitting there apparently for about 15 years. nib. i think they want like 100 bucks for a set. black and mill finish. i know there are a couple of datsun guys here.
    aaron sent my wheel!
    Feb 2004
    McMaster has 10mm x 1.5 jam nuts. If by jam nuts you mean thin nuts. These are 5mm thick...which would be about half the height of regular 10mm nuts.
    Senior Member robertob's Avatar
    Aug 2006
    Long Beach, Ca, USA.
    I'm not sure but I think you should sell me both mis-matched pieces
    R
    Feb 2004
    If you need that stuff...I've usually got a few in stock. I don't sell the junkers though, only race prepped stuff.
    Aug 2006
    Yeah - I figured you do. Building a set of wheels is pretty far down my list right now but I won't say no to the parts I will eventually need at the right price.
    Don't mean to thread-jack but I would like to find a cable rear brake backing plate and a whole CL450 front brake to lace up.
    Member racerchris46's Avatar
    Feb 2005
    Toronto, Ontario, Canada.
    So you want exactly what the first post has? A rear backing plate with a front hub? For what if I may be so stupid(er). Sidecar third wheel?I don't have any front CB77 brakes left to sell, but I think I have a rear I could part with, which are of course cable actuated (but designed for right hand sprocket).
    Which reminds me, thr guy I used to ride for, Giannini, he was going to try to put a Cb350 front backing plate on a CB350 rear wheel so he could have 2LS rear. Anyone ever done something like that?
  1. Cb77 vs Cl77 front hub
    By Livetoskate in forum Technical
    Last Post: 11-06-2012, 08:54 PM
  2. CB77 Rear brake and hub
    By jaguar in forum Wanted
    Last Post: 10-28-2010, 03:21 PM
  3. Identify a Honda rear hub?
    By eyhonda in forum Technical
    Last Post: 08-14-2009, 01:15 PM
  4. CB77 rear wheel axle diameter and does it
    By HackAsaw in forum Technical
    Last Post: 08-03-2008, 04:10 AM
  5. CB77 front brake
    By mikeinnh in forum Technical
    Last Post: 04-04-2007, 01:59 AM
cb77 rear drum brake
cl77 hub vs cb77 hub
