1979 cb650
1979 cb650
This is a discussion on 1979 cb650 within the Technical forums, part of the Caferacer.net Forums category; Hey guys I'm working on a cb650 I'll put up a project build soon. But I was wondering. I'm working on the rear hoop and ...
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By jcw
Thread: 1979 cb650
    Junior Member westhewelder's Avatar
    Nov 2017
    1979 cb650
    Hey guys I'm working on a cb650 I'll put up a project build soon. But I was wondering. I'm working on the rear hoop and trying to figure out the geometry I removed the shocks and moved them 100mm smaller from center to center on the mounting positions and the rear tire sits well past the frame.
    So put on the shocks and tried to get it to bounce past doesn't seem like it will. And I'm not a small guy. The plan is to have a flat brat seat so I can ride 2 up and if I want to put on a hump it's an option.
    Sent from my SM-G920W8 using Tapatalk
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Rear wheel travel listed 3.5 inches.
    Sounds like you should be ok. But to do it right, you would remove the spring and compress the shock to the bump stop to be sure. Unless the spring binds before that, which would be silly.
    TrialsRider likes this.
    Nov 2017
    I'll have to look into how you remove these I'll be out there tonight some time probably I'm screwing with wiring cleaning that up
    What he said! That's also the only way you can test your shocks to see if they are any good,
    or since they are stock shocks, how bad they are.
    Senior Member scramblermike's Avatar
    Nov 2012
    Agawam, Ma, USA.
    You will hate how it turns out with a long seat. It will look like a large popsicle stick. Take a piece of cardboard and cut out the size of the seat and put it on the frame. After you are done laughing you can then come up with a different idea
    Rome, GA, USA.
    I love loops. Fruit Loops.
    Aug 2012
    grants pass, OREGON, USA.
    really easy if you have the stock rear fender or the seat support piece
    a good rule of thumb is keep those clearances as they came from the factory
    taking springs off can be fucking harrnful to your blood blisters and is not recomended without proper tool
    they have some hellatious preload goddam japs love to preload the fook out of an oem shock spring on a 600 pound bike im sayin
    one shock soft cam setting ratchet strap on the same side as shock heave ho observe when bumper is well crushed
    3.5 inches of rear wheel travel would be a less than 3'' travel shock from stock i think that figure is wrong
    most oems would go at least 3.5 at shock into bumper ,which is more like almost 4.5 at axle
    so there
  1. CB650 gone...
    By cafecb650 in forum General
    Last Post: 05-17-2013, 03:09 PM
  2. 1979 Honda CB650 Custom Cafe Racer rare 79 cb 650
    By scoobarific in forum Bikes For Sale
    Last Post: 02-05-2013, 09:51 AM
  3. cb650 racer
    By jaguar in forum Bikes For Sale
    Last Post: 01-31-2012, 01:34 PM
  4. 1979 or same gen, CB650 camshaft
    By Andemusprime in forum Wanted
    Last Post: 04-13-2011, 06:42 PM
  5. 81 cb650 custom, on a 79 cb650 frame
    By ScrewyLouie in forum Project Builds
    Last Post: 01-31-2011, 09:12 PM
