Foale Frame designs - Page 5
Foale Frame designs
This is a discussion on Foale Frame designs within the Technical forums, part of the Caferacer.net Forums category; Actually, i majored in physics, with a minor in math and programming......
Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Like Tree3Likes
Thread: Foale Frame designs
  1. #41
    Member jordan's Avatar
    Jan 2017
    Qc canada
  2. #42
    jcw
    jcw is online now
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Attachment 87433
    ...not saying it made a big difference
  3. #43
    Jan 2017
    Qc canada
    What we really need is Robin Tuluie
    Junior Member schmorbraten's Avatar
    Mar 2018
    Why not going the path of Egli or Rau chassis,
    big diameter bachbone tube and the headstock goes right thru the tube, much more stiffer than attaching the headstock to the front.
  6. #45
    Jan 2017
    Qc canada
    Foale Frame designs
    Ran the analysis again with a 65mm*1.8mm spine, which yielded 14, 16, 85 % increases to the torsional, lateral, and longitudinal distortions respectfully. The total weight for the frame and sub frame with this thickness, just under 6kg, a roughly 1 pound saving from the initial thickness.
    I will sketch up an egli styli frame and see what that gives in terms of rigidity and weight.
    I will also see if a sort of tube based wishbone frame can’t be made to work for similar weights.
  7. #46
    Jan 2017
    Qc canada
    This idea i could get behind.
    Two shots of egli TZ frames, and a Rau cantilever frame. Rau took over from Egli when he called it quits.
  1. Maviryk Designs 4 cell lightweight lithium race battery
    By freedomgli in forum Parts For Sale
    Last Post: 01-08-2014, 10:22 AM
  2. tony foale book
    By coreyjdl in forum General
    Last Post: 05-20-2011, 09:15 PM
  3. Foale owners and bikes register.
    By ROSKO in forum General
    Last Post: 09-04-2005, 08:29 PM
tony foale motorcycle frame stressed member
