160 cam chain & clutch
This is a discussion on 160 cam chain & clutch within the Technical forums, part of the Caferacer.net Forums category; anyone have a good source for a honda 160 cam chain and clutch plates (both) or can I just change the fibre ones. The clutch ...
Results 1 to 3 of 3
    dch
    dch is offline
    Senior Member dch's Avatar
    Nov 2006
    Middle Earth, ct, USA.
    anyone have a good source for a honda 160 cam chain and clutch plates (both) or can I just change the fibre ones. The clutch is not giving any trouble but I'm doing the top-end and as long as it is out of the frame..., street use.
    dch.
    I love the smell of castor oil in the morning, but I have a Honda....and now a \'taco(s)...x2
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Wouldn't bother replacing the metal plates unless they appear to have a problem...never seen any even close to worn out or over heated.
    The CB175 cam chain should also fit the CB160. Although the part numbers might be different because they might have gone to a thicker chain (still fits) for the 175.
    I make up my own rivet link chains from "endless" chains and have to remove a few links from them. CB175 chains usually aren't too hard to find.
    dch
    dch is offline
    Nov 2006
    thanks JB, found a chain at servicehonda.com, they even had a right side air filter.
    I'm not that worried about the clutch.
    dch.
  1. Chain/Sprockets
    Last Post: 01-26-2012, 06:04 PM
  2. Tires & Chain
    By Gambler in forum Technical
    Last Post: 04-03-2010, 09:23 AM
  3. Different cam chain question
    By Bateman147 in forum Technical
    Last Post: 06-23-2008, 02:41 PM
  4. Cam Chain
    By ghetto_racer in forum Technical
    Last Post: 06-20-2008, 05:18 PM
  5. Is This Chain Right For Me?
    By dubyaohohdee in forum General
    Last Post: 03-15-2008, 08:18 AM
