Mikuni carbs on Honda CL350 - Page 3
This is a discussion on Mikuni carbs on Honda CL350 within the Technical forums, part of the Caferacer.net Forums category; Originally Posted by XB33BSA i use a clear hose attached to the float bowel drain to observe the actual level in fact i ride with ...
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Like Tree2Likes
Thread: Mikuni carbs on Honda CL350
  1. #21
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    in fact i ride with them on the carbs
    i route the hose up the side of the carb u bend it straight down so water cant get in
    makes for a quick diafgnosis check if out riding and having fueling issues
    on the vm mikuni as well as the keihins you want the level to be at least 6mm below gasket
    if you have a pamco in there yank it off and put the points back in you have to or you could go mad chasing a carb problem that is really an ignition issue
    the pamco is good unit but they fry easy from simple little wiring snafus
    And I set them to 3-4mm below the gasket surface - no lower.
    The answer is that if you set fuel levels and not FLOAT levels you will be far more able to adjust them and see the effects. Your fuel levels will also be much more accurate.
    CrazyPJ has some CB360 carb synch tubes in 6mm x .75mm that happen to match many smaller sized Mikuni and Keihin float bowl drain screws.
  2. #22
    Junior Member Geezergen's Avatar
    Sep 2018
    Titus, Al
    Well finally got my new jets and jet needles and stuff in to try the new set up on the Mikuni VM carbs. This setup is almost perfect! Runs great all the way thru the mid range and idles perfect. Feels a little rich on the top end but no spitting or missing just feels a little slow to accelerate. I will try a 195 main and see how it feels. I really appreciate all the help from you guys getting this bike straightened out. On another note, I have ordered some first over pistons and rings for the 1969 Yamaha R3 and will let you know how that project goes. Again, many thanks.
  3. #23
    Quote Originally Posted by Geezergen View Post
    ... Feels a little rich on the top end but no spitting or missing just feels a little slow to accelerate. I will try a 195 main and see how it feels....
    then just drop the main jet needle by one notch,
    changing the jet size will affect a change throughout the whole operating range, changing the needle position changes only the 1/2 to wot operation.
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    As far as I know adjusting the needle height only effects 1/4 to 3/4 throttle.
    TrialsRider likes this.
  6. #25
  7. #26
    Oct 2013
    Colchester, England
  8. #27
    Sep 2018
    Titus, Al
    Well after doing a plug chop, it looks like it is too lean so I am going to go to 210 mains. (yes I know I should try the 205's but I don't have them so I will try what I have and go from there.) The needles are in the highest position so bigger jets are the next option. If the 210's are too rich I can send for the 205's and play with them and the jet needle and get it just right.
    540nova likes this.
  9. #28
    Aug 2012
    grants pass, OREGON, USA.
    a short sound couple bite of my 350 twin adv-rambler
    more to
  10. #29
    Aug 2012
  1. best source for cb-cl350 mikuni vm carbs kit
    By kochic in forum Technical
    Last Post: 03-30-2011, 04:14 PM
  2. 2 MIKUNI VM22 CARBS FOR SALE
    By 956 in forum Parts For Sale
    Last Post: 06-29-2009, 03:08 AM
  3. Looking for Mikuni vm 30mm carbs
    By cafe350 in forum Wanted
    Last Post: 05-29-2009, 01:31 AM
  4. Mikuni 34mm carbs on a cb450?
    By borzwazie in forum Technical
    Last Post: 03-11-2008, 09:57 AM
  5. CB450 32mm mikuni carbs (almost new) FS
    By robertob in forum Parts For Sale
    Last Post: 04-25-2007, 07:08 PM
Tags for this Thread
