1978 Goldwing fuel tank removal help needed.
This is a discussion on 1978 Goldwing fuel tank removal help needed. within the Technical forums, part of the Caferacer.net Forums category; This is my 2nd post here. I'm starting a Goldwing Cafe Racer build and am in need of a little help. Seems my first post ...
Results 1 to 5 of 5
    Junior Member GChambers's Avatar
    Jan 2019
    This is my 2nd post here. I'm starting a Goldwing Cafe Racer build and am in need of a little help. Seems my first post in the New Members section got lost in the abyss. Anway....
    I'm trying to remove the fuel tank from this 78 Goldwing. I've followed all the steps in the shop manual and the tank WILL NOT BUDGE. I'm trying to move it back into the frame but it's not going anywhere. It's like the tank is still bolted in somewhere. The seat brace is removed. The fenders are removed. The tank bolt on the back of the tank is removed. The petcock is removed. The battery box is removed. I'm kinda lost for ideas on what's still holding it in. Does anyone have some advice?
    Thanks in advance.
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Can’t help you with the tank, but....
    Really?
    Aug 2012
    grants pass, OREGON, USA.
    ah yes a com,mon issue she is wedged
    you need lube any kind of oil or gease heated up to flow
    pour it top center so it fiows evenly down and around the sides/bottom
    then carefully pry up with something like 1x2 wood stakes
    Jan 2019
    Really?
    Yes. Really.
    - - - Updated - - -
    Interesting. Thank you for the tip. Greatly appreciated.
    Jan 2019
    Thank you. A little persuasion got it loose.
  1. Need help to identify this Fuel Tank
    By Andytcc in forum Technical
    Last Post: 10-10-2017, 10:39 AM
  2. 75' Honda Goldwing Cafe Build (HELP)!!!
    By Joseph Lemanski in forum Technical
    Last Post: 05-06-2014, 03:05 PM
  3. goldwing on craigslist
    By snorkelfork in forum General
    Last Post: 03-04-2008, 08:31 PM
  4. kneesliding a goldwing
    Last Post: 08-18-2007, 05:02 PM
  5. tank repair or new tank needed
    By obiwan40 in forum Wanted
    Last Post: 03-20-2006, 11:10 AM
goldwing gas tank removal
