this will probably start a fight - Page 2
This is a discussion on this will probably start a fight within the Technical forums, part of the Caferacer.net Forums category; if you're prepared to pull it apart again and fit new valves when it turns out to be a crap idea, reface them. if you're ...
Results 11 to 20 of 27
Like Tree2Likes
Thread: this will probably start a fight
  1. #11
    Nov 2014
    Melbourne, Australia
    if you're not, don't.
    woodsman likes this.
  2. #12
    Sep 2008
    Rochester, New York, USA.
    yup, if I had a honda engineer who worked there in 1965 tell me to go ahead it's fine, I'd be all about it, it's the not knowing all the information about the manufacture of a part that you're working on that concerns me. I tried scratching the face with an hss endmill and I could scratch it up but I couldn't scratch up the tip, so with a really really basic hardness test, it gave me an idea that whatever surface treatment was on the face isn't there any more.
  3. #13
    Senior Member Cyorg's Avatar
    May 2014
    Do the valves look like they may have been ground before? Probably not easy to tell if it was a light skim and if you don't have a NOS one to compare it too.
    You're welcome for the copy of the bulletin btw.
    "Non urinat in ventum"
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    I don't think that CB350 valves were stellite tipped or on the seat faces. Honda, and others used two piece valvee with different head and stem materials. Heads used to be heat treated or coated with something to get that hard skin, but teh valves were OK to grind, even though Honda said don't do it.
    The problem with two piece valves is that on a race motor that is revved hard, every so often a head will fall off and punch a hole in other parts. We had that happen on a CB160 years ago. On a street motor, not an issue, on a racer that's ridden hard, fit new valves.
  6. #15
    Aug 2012
    grants pass, OREGON, USA.
    roc that is a good point and the gist of the question
    the reason they did the hardfacing in 79 and later is the ban on leaded fuel ewh ?"as you promote the 350 twin is early 60's tech when unleaded fuel was non existent nno ?
  7. #16
    Aug 2012
    aoso if you bakcut the valve @30 degees you can actually bring that angle into the worn cupped area of the valve
    effectively narrowing the contact area ,then you are not tricked into grinding the contact area all the way up into the backcut because its nolonger there
    on the ex valve especially the contact wants to be pretty close to rhe outer dianeter any way to enable onseat closed time to have the best abjlity to cool down because vthe hottest zone is the outer edge
    and that is the only way nthe ex valve can be cooled is on seat time
    of course the intake valve wants to have the contact zone nearer to the middle area of the seat angle cut for best flow at low lift time
    most of the bused valves i have inspected have not insignificant stem wear anyway and the stem to guide service limit is reached quite often with combined stem and guide clearance it is a bit tricky to measure the stem to guide clearance
    but should be checked as layed out in the FSM
    i cant remember if FSM mentions this here part but the clearance bmust be checked with clean dry stem and guide
  8. #17
    May 2014
    I always understood that the changes surrounding lead had more to do with the seats in most cases.... although I am looking at that from my own personal point of view. Most of the stuff I have is from long before lead removal and folks talk about replacing seats, but not much discussion on valves. Usually stainless replacements now and nothing really special. As for Honda, they did it earlier (pre unleaded) to reduce wear.
    Name:  350 manual.jpg
Size:  154.3 KBName:  350 manual 2.jpg
  9. #18
    Jan 2015
    San Diego, CA
    I always believed that lead had little to do with anything other than being a cheap additive.......to bring up the octane rating of poorly made fuels.
  10. #19
    Mar 2010
    , IL, .
    valve seat recession used to be a common topic on may forums as leaded fuel became less available. It was rarely an issue with valves - just seats and only for machines not designed for unleaded gas. TEL is of course one the earliest and most used knock inhibiting compounds which all gasoline is laced with because it all has a naturally low resistance to detonation (knock). Then it was replaced with nice clean MTBE which turned out to be worse than lead. Alcohol - ethanol and methanol have much higher knock resistance than gasoline and diesel is way up there.
  11. #20
    :I don't see any fights happening here, seems we are all pretty much on the same page.
    Did you ever notice how Hydrocarbon fuels including Octane contain exclusively Hydrogen and Carbon molecules, right up until somebody comes along and tries to improve it with an additive, which usually messes it up for either the machinery or the environment :|
  1. Replies: 5
    Last Post: 03-07-2018, 10:37 AM
  2. Fight night
    By Magster in forum General
    Last Post: 12-08-2016, 02:54 PM
  3. Mayweather/Pacquiao fight
    By o1marc in forum General
    Last Post: 05-09-2015, 06:42 PM
  4. This will probably start a fight....
    By A.D. in forum General
    Last Post: 07-25-2009, 03:21 PM
  5. Fist Fight!!!
    By chetriply in forum General
    Last Post: 11-24-2006, 05:18 PM
