How to mount ignition switch
This is a discussion on How to mount ignition switch within the Technical forums, part of the Caferacer.net Forums category; I have a 1982 cb450t and it did not come with keys/ignition. It had a switch and anyone could ride away if I left it ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree8Likes
Thread: How to mount ignition switch
    Junior Member Monsier_Mom's Avatar
    Mar 2019
    I have a 1982 cb450t and it did not come with keys/ignition. It had a switch and anyone could ride away if I left it in the parking lot. I've since replaced the switch with an aftermarket ignition and I just randomly just mounted in any available hole. I think the original ignition slot was integrated into the cluster. I eventually want a cleaner look and am looking for ideas to mount the ignition key so that it if flush... With something. Ive done a bunch of research and am coming up empty. Does anyone have suggestions? I'll post a picture soon.
    Sent from my Moto Z (2) using Tapatalk
    Mar 2019
    Quote Originally Posted by Monsier_Mom View Post
    Pics
    ...I just randomly just mounted in any available hole....
    Dear Penthouse forum....
    J/K
    the stock location was at the bottom of the stock dash just in front of the handlebars. If you don't have a stock dash then you can mount it anywhere. Most 70's hondas have the key mounted under the tank by the front frame downtube. most BMW's have it in the headlight bucket with a trick flat key.
    if you just bought a generic flush mount key switch, most guys in the 70's made mounts like this to mount the key to the top clamp:
    https://www.ebay.com/itm/NEW-IGNITION-SWITCH-RELOCATION-PLATE-BRACKET-FOR-HONDA-CB750-CB-750-/161690444669
    I did see one once where the owner mounted the key switch in the triple clamp stem nut. he machined his own aluminum nut with a housing for the keyswitch and since steering stems are hollow he ran the wires straight down through the bottom of the triple clamp. Wish I had a pic of it because it was trick.
    Mar 2019
    J/K
    Can you link me a photo of the key under the tank. I like that idea and have heard of it in forums but could never find a picture.
    Here is a pic....
    Monsier_Mom likes this.
    Senior Member Mike 40M's Avatar
    Feb 2017
    Sweden
    Another place could be under the saddle, as Norton did. By placing it there you get a nice cable layout, having it close to the battery.
    Alternatively you could mount a non working ignition switch in an obvious location as a decoy
    and make the real ignition switch a toggle or even better a magnetic tether switch somewhere no thief will notice it.
    Remember when they used to mount the key on the left side panel where it would hit your leg? That was about the worst location ever.
    We have to put these on all our competition dirt bikes this year: https://www.trialstoreusa.com/jitsie...-with-lanyard/
    Ews
    Ews is offline
    Senior Member Ews's Avatar
    Jun 2015
    Lewiston Idaho
    I am going to run into a similar issue when i replace my gauge cluster with a new digital one. My solution will be to fabricate a new mounting bracket that will hold the new speedo/tach, likely from some good aluminum, or Vibranium if I the King of Wakanda ever pays up after losing that poker game. I like the key right above the handle bars so I dont forget to turn pull it out when I get off my bike.
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    I welded a small mount next to the battery box hidden away, but in retrospect, it's better in a position you can easily see and reach when sitting on the bike. Trying to insert a key into a keyhole you can't see is stupid. Flipping a switch is OK...
    Mar 2019
    Here is a pic....
    So that's how it looks. Yeh I would rather just have it by he handlebars. I ended up finding a bracket on eBay using the link you sent. Hopefully it looks good.
  1. which relay for ignition switch?
    By jackshite in forum Technical
    Last Post: 01-31-2012, 11:08 AM
  2. Early 80's Suzuki Ignition Switch
    By Hellions in forum Wanted
    Last Post: 10-07-2011, 11:28 PM
  3. Location of Honda CB360 Ignition switch?
    By shidifen in forum Technical
    Last Post: 01-29-2010, 03:22 PM
  4. Wiring an Ignition Switch
    By ZouLou in forum Technical
    Last Post: 08-17-2009, 09:43 AM
  5. CB500T Ignition Switch / Lockset
    By KrooklynCB in forum Wanted
    Last Post: 10-14-2006, 06:50 PM
