Rear Set Problem on Guzzi V50 Project - Page 2
This is a discussion on Rear Set Problem on Guzzi V50 Project within the Technical forums, part of the Caferacer.net Forums category; Just a thought regarding the rear master cylinder. Would it be possible to turn it around?. I'd guess a longer brake hose would be needed, ...
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree1Likes
Thread: Rear Set Problem on Guzzi V50 Project
  1. #11
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    Just a thought regarding the rear master cylinder. Would it be possible to turn it around?. I'd guess a longer brake hose would be needed, and the linked brakes line (if still fitted) might be a issue.
  2. #12
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    That's usually too far back unless you currently ride with your butt on the pillion part of the saddle., they are suppose to be underneath your so that when your get up on them with the balls of your feet you look like a jockey on a race horse (centred) . Pegs too far back will force too much weight transfer to the bars, thats' not comfortable or optimal for riding.
    I tend to agree with the above...
    Rearsets too far back will put more weight on your wrists. This is a dealbreaker for a lot of people.
    It also prevents you from using your legs effectively on a bike. This is more a riding style difference and there are plenty that sit straight on the seat and steer. I tend to need to use my feet and legs.
    Basically what he said.
  3. #13
    Junior Member Mr Toucan's Avatar
    Jun 2019
    Kent, England
    Just looked at this and I think you're right - sketching some ideas for linkage now - Cheers
    - - - Updated - - -
    .....and with a back like mine!
