Carb issue Superdream CB250n Cafe Racer - Page 2
This is a discussion on Carb issue Superdream CB250n Cafe Racer within the Technical forums, part of the Caferacer.net Forums category; Hallsie. Assuming you have a decent spark I'd check to see if the plug's wet. My guess would be a dodgy float, stuck float valve ...
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Like Tree1Likes
Thread: Carb issue Superdream CB250n Cafe Racer
  1. #11
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    My guess would be a dodgy float, stuck float valve or blocked pilot jet.
    You've been working on the bike for a few years now, when did you last clean the carbs?
    Might be a good idea to get them in a ultrasonic cleaner.
    If you can get the bike over to Colchester I could take a look at it for you.
  2. #12
    Nov 2008
    If you have 3 jet carbs, (highly likely) the only thing to do is re-fit airbox. The alternative is get hold of 2 jet carbs from a Canadian model. It's been done to death about the late model Honda 3 jet carbs,(1978~82) they were also fitted to CB750 and CB900 DOHC and are just about impossible to do anything with. Leon Moss, when he did carbs for Honda Britain and USA 'Superstock' blocked the primary main jet then re-worked the internals for the secondary mains. He ran a small bore tube inside float bowl for the pilot system. It was a ton of work. I can tell you whats causing the problems but have no idea how to fix your carbs, they don't respond the same as earlier CV as fitted to CB/CJ 250 / 360, The transition from primary main jet to secondary main jet causes a very rich mixture as slide starts to lift, if it were possible to lower the needle it would help a little as you need to lean out the transition
