Need help with cb350 clutch cable adjustment
This is a discussion on Need help with cb350 clutch cable adjustment within the Technical forums, part of the Caferacer.net Forums category; Hey guys, I need some help on adjusting the clutch cable properly. I've downloaded the shop manuals, but I'm still confused. I've got step one ...
Results 1 to 2 of 2
    Danielson2881's Avatar
    Oct 2007
    I've got step one covered. I've screwed the upper cable adjuster all the way into the clutch lever bracket.
    Step two is were I get a little confused. I think the new cable that I purchased is a little different from the oem one. The new one has the adjuster on the bottom and the locking nut on top. Here is a picture of what it looks like
    Do I want to screw the adjuster all the way into the side cover and then do my adjustments on the clutch adjuster? (Losen clutch adjustment locknut, then turn clutch adjuster CCW until slight resistance is felt and then back of 1/4 turn?
    What am I missing?
    Moderator ROSKO's Avatar
    Feb 2005
    at the sidecover you want to take up any slack with the locknut adjuster. Then turn to resistance and 1/4 back. then fine tune with the adjuster at the lever.
    BORN TO LURK, FORCED TO WORK.
    www.NYCvinMoto.com
    www.VinMoto.org
  1. new "cafe" length MP clutch cable for CB350's
    By snorkelfork in forum Parts For Sale
    Last Post: 03-29-2011, 04:01 PM
  2. clutch adjustment first post
    By caletcb in forum Technical
    Last Post: 02-28-2011, 01:54 PM
  3. Q's about Clutch Cable, throttle etc.
    By eboggs in forum Technical
    Last Post: 06-11-2010, 04:41 PM
  4. Clutch Adjustment
    By ZouLou in forum Technical
    Last Post: 06-01-2008, 09:30 PM
  5. Clutch Cable Replacement?
    By Lorenzo in forum General
    Last Post: 06-18-2006, 01:57 PM
adjusting cb350 clutch
cb350 clutch adjustment
cb350 clutch adjustment screw
