CB500T petcock?
CB500T petcock?
This is a discussion on CB500T petcock? within the Technical forums, part of the Caferacer.net Forums category; Does anybody know if a different petcock will fit on a 1975 CB500T tank? The largest diameter of the threads is 20mm...I don't know the ...
Results 1 to 4 of 4
Thread: CB500T petcock?
    Member windupdevl's Avatar
    Nov 2007
    modesto, ca, USA.
    CB500T petcock?
    Does anybody know if a different petcock will fit on a 1975 CB500T tank? The largest diameter of the threads is 20mm...I don't know the pitch...I'm hoping its the same as the petcock on the '75/'76 CB500....and ideas?
    Eschew Obfuscation
    Eschew Obfuscation
    Senior Member robertob's Avatar
    Aug 2006
    Long Beach, Ca, USA.
    It's a twin-outlet one, same as CB450, CB350 and a bunch of others. I don't know if it's the same as the 4-cyl SOHC bikes.
    Nov 2007
    modesto, ca, USA.
    Yeah, I was hoping to put a single outlet petcock on the tank, since my 550 doesn't need the dual outlets....The 550 petcock is much to small to fit on the 500t bung but I don't know if any other single outlet petcocks will fit....
    Eschew Obfuscation
    Aug 2006
    CB175 or 125 I think has the same style but with one outlet.
  1. CB500T Petcock Replacement Solution
    By windupdevl in forum Technical
    Last Post: 01-15-2011, 08:56 AM
  2. petcock!
    By txchainsawgogi in forum Wanted
    Last Post: 11-07-2009, 12:19 AM
  3. Petcock
    By oldschoolorange in forum General
    Last Post: 10-31-2008, 11:08 AM
  4. petcock bad???
    By 56cbr600rr in forum Technical
    Last Post: 08-26-2008, 12:53 PM
  5. Need Petcock for 76 CB500T
    By JWood in forum Wanted
    Last Post: 08-31-2007, 05:23 PM
1975 cb500t petcock
1975cb500t petcock
anyone know where to obtain petcock and 1975cb500t
cb500 dual outlet petcock
cb500t 1975 petcock
cb500t petcock
cb500t petcock replacement
