JD Brake info
JD Brake info
This is a discussion on JD Brake info within the Technical forums, part of the Caferacer.net Forums category; Model - OD x shoe width - Swept area - Braking coefficient H1 (200mm)- 7.90" x 1.4" - 34.74 - 137.22 CB450 (200mm)- 7.88" x ...
Results 1 to 6 of 6
Thread: JD Brake info
    Senior Member aaron's Avatar
    Mar 2002
    Melrose, MA, USA.
    JD Brake info
    CB450 (200mm)- 7.88" x 1.18" - 29.21 - 115.08
    mvdusa.com
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    aaron, is swept area an inch measurement?? ie, square inches?? so the t500 has almost 34.25 square inches swept??
    please esplain for us.
    im so damned espanol....
    just wondering.
    Mar 2002
    Melrose, MA, USA.
    Hello Joe,
    Yes the Swept area is in square inches. The I've been going by is from Eurospares. Here's the link:
    http://www.eurospares.com/drumbrak.htm
    Aaron
    Mar 2002
    , , Turkey.
    wow, i never would have thought there was that much swept area! ive never actually don the math to see. it makes me want to pull my brakes apart to do some measuring and math! i will say this, although ive never seen a t500 drum fail in stock form, i know people have complained about them cracking etc... ive also been told they came cracked from the factory (just like cb350 frames came crooked??).
    later
    JD
    JD is offline
    Senior Member JD's Avatar
    Mar 2002
    NY
    I....like....big brakes and I cannot lie! You other brothers can't deny!
    Mar 2002
    , , Turkey.
    sir brake alot.....
  1. Wiring a brake switch to the front brake
    By cafe350 in forum Technical
    Last Post: 09-07-2009, 08:46 AM
  2. more nhms info
    By joe c in forum Vintage Motorcycle Racing
    Last Post: 04-16-2009, 01:43 PM
  3. just trying to get some info....
    By chello in forum General
    Last Post: 08-09-2008, 09:42 AM
  4. Aermacchi info?
    By ROSKO in forum Technical
    Last Post: 02-28-2006, 02:48 PM
  5. VW Info
    By aaron in forum Technical
    Last Post: 11-07-2004, 02:49 PM
