Tank for XS650
This is a discussion on Tank for XS650 within the Technical forums, part of the Caferacer.net Forums category; It seems I put a technical question in the General forum. Will that matter much? Here's a repeat: I need a little guidance in how ...
Tank for XS650
It seems I put a technical question in the General forum. Will that matter much? Here's a repeat: I need a little guidance in how to find and fit a suitable tank for my XS cafe project. The bike has clip ons and I'm having a bit of time figuring out how to know which tank might be right for me,(the stock tank works, but I don't want its' weight or look) I see lots of lovely ones on the web, but how to tell if they would work? Any suggestions, leads, or hints would be greatly appreciated? Thanks a ton (up).
Jamie
Senior Member
no problem, moved to technical.
As far as finding the right tank, take measurements (especially of the tunnel width and height) and any vendor should be able to tell you which of their tanks will fit. For installation find someone who can weld and make some custom brackets. You're in southern Conn. but not too far from our resident master welder's shop in Wakefield, Mass. Aaron may chime in here.
- You may not post replies
- You may not edit your posts
Forum Rules
By elementfmfl in forum Parts For Sale
Last Post: 05-28-2012, 07:46 PM
By Pinche Chingadera in forum Wanted
Last Post: 02-27-2010, 11:30 AM
Last Post: 09-02-2009, 08:58 AM
By robertob in forum Project Builds
Last Post: 11-01-2008, 02:25 AM
By ZouLou in forum General
Last Post: 11-11-2007, 06:14 PM
install a tank on xs650
