oil filter kit for '68 cb350
This is a discussion on oil filter kit for '68 cb350 within the Technical forums, part of the Caferacer.net Forums category; I've been looking for an oil filter kit for my wife's 1968 cb350. All the filters/kits I find are for the 72-77 models. Does anyone ...
Results 1 to 10 of 11
    Member xs650joe's Avatar
    Dec 2007
    Cowtown, OH, USA.
    I've been looking for an oil filter kit for my wife's 1968 cb350. All the filters/kits I find are for the 72-77 models. Does anyone know where to find a kit for the older cb350's? Will the 72-77 model kits work? We specifically need the o-rings. Sorry if this is a dumb question but hey, I'm a yamaha guy. Any help/feedback is appreciated.
    Joe
    CO-OH Vinmoto
    nothing to see here...please move along
    , Decrepit and Decomposing, .
    I know nothing to answer your question other than this
    orings can usually be had in any and all sizes from a local bearing/seal/hose place
    and if not
    any number of places like MSC Direct can have them to you the next day if you order before 2pm
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    alot of the honda rings are honda only. like the steering stem bearings.
    sorry, wish i knew the answer, i think they will cross over, but im not 100%.
    What are you trying to accomplish? For the most part the stock oil "filter" on the cb350 seems to work fairly well. I've seen a few racers that have plumbed a normal spin on oil filter to a cb350 but I don't know of any bolt on kit.
    Or in addition to MSC, McMaster will have almost any o-ring you can measure up, in metric sizes as well.
    www.mcmaster.com
    Dec 2007
    Cowtown, OH, USA.
    We aren't doing anything fancy. Just changing the oil but she wanted to be thorough and replace the filter and o-rings while she's doing it. I found this kit but it says it is specifically for the 72-77 models.
    I suggested using a "generic" o-ring but she would prefer the honda because well she's like that. Thanks for all the help.
    Joe
    CO-OH Vinmoto
    Senior Member burntblacktoast's Avatar
    Mar 2008
    bellflower, il, USA.
    Uh, I'm just assuming that the particular kit pictured is from a 72-77 cb350f four cyl, not from an earlier 68 cb350k. I've given my 70 cb and 72 cl twins a good dis-assembling and have determined that the oil filtration system consists of the centrifugal oil "separator" and filter screen on the bottom of the oil pump contained in the left hand crankcase cover. There is a 45mm o- ring in the "seperator" assembly that could be found through your friendly neighborhood honda dealer, but as far as that paper cartridge, you may have quite a time getting that installed on your 68 cb350. I'm gonna wait right here for someone to kindly correct me.......
    Senior Member ttilghman's Avatar
    Jul 2005
    orange county, ny, .
    nope...no cartidge on the CB350 twins. just the centrifugal sludge collector.
    Mar 2002
    , , Turkey.
    yep, thats for the 350/4. the one in the pic. the one on the twin only has a slinger under the right side cover. there are 2 orings. one under the actual cover. and one that goes i the slinger itself. if you pull the slinger cover, you will need a new clip to hold the cover on. do not reuse the old one.
    i have seen paper filter retrofits, but i dont think thats what your looking for.
    here are the honda part mubers
    oil filter cover oring
    91355-415-000
    filter oring
    91309-286-000
    circlip
    906040292-000
    Dec 2007
    Cowtown, OH, USA.
    Cool, thank you all for the help. If you come through Columbus I'll buy you a beer.
    Joe
    CO-OH Vinmoto
    Feb 2006
    Joe, gimme a call when you go to clean the filter. It can be a little tricky getting the centrifugal filter apart.
    Buy me a beer too.
  1. Air filter comparison
    By crazypj in forum Technical
    Last Post: 12-07-2011, 01:54 PM
  2. 1971 CB350 Air Filters & Filter rod
    By patritag in forum Wanted
    Last Post: 04-17-2011, 06:29 AM
  3. Replies: 6
    Last Post: 08-26-2010, 10:33 PM
  4. K & N Filter on a cb350?
    By jimd118 in forum General
    Last Post: 08-24-2010, 02:18 PM
  5. CB350 Centrifugal Oil Filter
    By mercer854 in forum Technical
    Last Post: 03-27-2009, 09:05 PM
cb 350 oil slinger
cb350 oil filter
cb350 oil filter kit
cb350 oil filter o'ring assembly
cb350 oil kit
cb350 oil slinger cover
cb350 twin oil filter
cb350k oil filter
what o rings are in a cb350 oil filter
