Cam Chain
Cam Chain
This is a discussion on Cam Chain within the Technical forums, part of the Caferacer.net Forums category; So as many of you know I'm clueless... I'm in need of specific directions on removing the top end of my bike. I have the ...
Results 1 to 7 of 7
Thread: Cam Chain
    Senior Member ghetto_racer's Avatar
    Feb 2005
    Woburn, ma, USA.
    Cam Chain
    So as many of you know I'm clueless... I'm in need of specific directions on removing the top end of my bike. I have the motor out and the top off.. I'm looking at the cam chain and thinking.. now wtf do I do so I don't break anything.
    http://picasaweb.google.com/jdonovan...70462657230258
    Thanks
    J'lahoozahaherr'D
    J \'BuYaMinI\' D
    Senior Member Bateman147's Avatar
    Kingston, WA, USA.
    There should probably be a master link with a clip in the cam chain - it'll look just like any other master link, but smaller. Turn the motor over 'til you find it. Remove the clip (trying not to drop it down the cam chain tunnel). It usually takes a sharp edged pair of pliers to back the clip out. Remove the sideplate (don't drop it), then remove the link (don't drop it either). It's best to use a couple of pieces of safety wire on each end of the chain to keep from losing it in the bowels of the motor unless you're going for complete disassembly. With that the head will come off.
    To get the cam out you'll need to remove both cam bearings on the left and right side. The right side is easy to see the fixing bolts, left side is behind the points plate. You'll need to remove the advance mechanism and points plate to get to them. Once you've got both cam bearings out you cam pull the rocker pins and remove the rockers. At that point the cam should come out - right side first.
    Michael
    FR
    FR is offline
    Senior Member FR's Avatar
    Nov 2004
    Essex Jct, VT, USA.
    I'd be really surprised if there's a master link on the cam chain, my old 450 had a riveted link. In such a case you'll need a chain breaking tool to remove it. The good news is you'll be able to use the chain breaker to put the new cam chain with the riveted link together!
    FR
    FR
    Moderator ROSKO's Avatar
    Feb 2005
    check your email. I am sending you the manual. Just because I am too shitty at typing to write out the procedure.
    Kingston, WA, USA.
    When I glanced at that I thought it was a 175/200 -
    With no master link follow Rosko's manual. The rest will be the same.
    Michael
    Feb 2005
    Woburn, ma, USA.
    WORD
    J \'BuYaMinI\' D
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    i sent you pretty good directions. did you get them?
  1. CB750 cam chain
    By UngaWunga in forum General
    Last Post: 08-27-2010, 03:25 PM
  2. Replace chain
    Last Post: 07-17-2010, 07:36 PM
  3. New chain riveting
    By BB73 in forum Technical
    Last Post: 05-04-2009, 11:25 PM
  4. Is This Chain Right For Me?
    By dubyaohohdee in forum General
    Last Post: 03-15-2008, 08:18 AM
  5. cam chain tensioner
    By jeepurze in forum Wanted
    Last Post: 01-27-2006, 08:33 PM
delete chain in mastercams
