fork brace
fork brace
This is a discussion on fork brace within the Technical forums, part of the Caferacer.net Forums category; I'm looking for the part # for the fork brace (heavy steal bracket/brace) that goes between the forks and under the front fender. If anyone ...
Results 1 to 10 of 17
Thread: fork brace
    72CafeRacer's Avatar
    Jun 2008
    fork brace
    I'm looking for the part # for the fork brace (heavy steal bracket/brace) that goes between the forks and under the front fender. If anyone knows the part name or #, i would be grateful. I don't have one on my bike and i have read things about ppl having problems without it and some people don't.
    if you ride anywhere where the roads are bad then you will feel the front end flex a tremendous amount. I ran my K5 without one for 6months and the worst was doing transitions over uneven roadways, the front end would flex like a rubber band and snap back once there wasn't any pressure on it. Also during hard cornering you can feel the wheel trying to distort out of line as the forks twist slightly. If you want to see how much distortion you will get in the front end sit on your bike, hold the front brake tight, and wiggle the bike side to side slightly (or even just wiggle the front end slightly) and watch your front tire - you will see all sorts of subtle but funky angles of deflection in the tire relative to the fork. Really the issue is that without something connecting them the sliders can move differently from each other - you need something connecting the sliders together that will not be affected by the movement of the tires.
    the fender mount was never sold as a seperate piece - always sold as part of the fonr fender since it is rivited on. The best way to get one is to buy an old beat up fender off of ebay and drill, grind, or cut the rivits off and take the brace out. It is still not as strong as having a front fender attached and some people will just buy garbage front fenders and cut them so that they are the size of the brace.
    My suggestion is to go find a teleflex fork brace or a tarozzi fork brace for a cb750 and put that on instead. Really these bikes should have thicker forks, the 35mm are too flimsy for 500lbs+ bike so they need all the rigitiy they can get. Jimhinshaw on ebay is a tarozzi dealer and should be able to get you one if you e-mail him, same with omars, etc.
    Don't confuse a fork brace with a tweak bar. Tweak bars are for adding rigidity in extended tubes and clamp to the actual fork tube, a real fork brace attaches to the sliders. Some racers use both, which isn't a bad idea but really you need a fork brace if anything.
    Feb 2006
    Stock fork braces are usually an integral part of the fender. They're riveted on. Find an old CB fender, drill out the rivets and mount whatever universal fender to the brace you want.
    Some distributors still carry universal fork braces for older bikes, but you kinda have to dig a little. Find a shop near you that sells parts from Dixie International or KK Supply. They might be able to find one in their warehouse.
    If you don't care about a front fender and want a trick ol' school chopper solution, look up "tweak bar" on ebay. Not as effective as a fender-style brace that mounts to the sliders, but it'll give you some rigidity. Just make sure you get one made for a 750.
    EDIT: Dammit Geet, you're quick.
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    ...and while you're talking to jim from fast-from-the-past, consider getting some rearsets for that thing...torazzi is expensive, but easy, especially for 750's.
    iphone generated fag
    Jun 2008
    thnx for all the help
    totally missed the stock pegs with clubman bars....I should have seen that like Pamela Anderson's Hep C rash (from space)....
    yeah man, get some rearsets on that biddy.
    Jun 2008
    They don't make them for 1972...75 and below only i believe. Jim said they don't make em for my 1972. So i'm building my own from an old front fender i bought online today..what does the back brace look like? anyone got a pic
    ooops....looked again and it looks like the previous owner fucked you for tarozzi rearsets - you need the passenger peg frame extensions to mount them and, well, it looks like your bike has had them hacked off.
    There are other options, the one I suggest is getting honda 929 (RC51) rearsets and some frame clamp brackets and mounting it that way because....well...your previous owner was a fucking idiot.
    and of course right after I post that....you remove the pic from your signature
    ummmmmm...ok...what don't they make for 1972? the fork brace or the rearsets?
    75 and below should cover 1972. the cb750 K frame remained unchanged from 1969 to 1976. The F frames and the 77-78K frames are slightly different in the seat area.
    If you are talking about the fork brace I don't understand since the only difference between early and later cb750 fork legs are the brake mounting tabs.
  1. New Fork Brace
    By tylermoney in forum General
    Last Post: 09-30-2011, 03:12 PM
  2. Fork brace
    By YucA in forum Technical
    Last Post: 02-15-2011, 11:08 AM
  3. Fork Brace
    By Rwalker004 in forum Technical
    Last Post: 04-30-2010, 12:53 PM
  4. Fork Brace
    By Whitehurst in forum Parts For Sale
    Last Post: 01-08-2009, 12:47 AM
  5. Fork Brace
    By xkillerbx in forum Technical
    Last Post: 05-02-2008, 12:23 PM
cb750 fork brace
cut front fender to make fork brace
tarozzi fork brace fender problem
