carbs the same on 71 and 72 cb350?
This is a discussion on carbs the same on 71 and 72 cb350? within the Technical forums, part of the Caferacer.net Forums category; bought a bike about a month ago and noticed that the idle control screw on the right carb had been snapped off somehow by the ...
Results 1 to 3 of 3
    Tanner's Avatar
    Jun 2008
    bought a bike about a month ago and noticed that the idle control screw on the right carb had been snapped off somehow by the previous owner. part of the metal that is cast into the body of the carb is also snapped off so there is no way around this but to buy a new carb or a new set of carbs.
    i have two options so far:
    -i have a chance to buy a right side carb from a '72 cb350....will this work on my '71 cb350 with original 71 left carb?
    -i also thought about just upgrading and buying mikuni carbs. is this a waste of money?
    Senior Member monkey's Avatar
    hull, mass, USA.
    mikunis are great... but if you are planning on ever racing in a stock class you may want to keep em. i would first try the inexpensive option first.
    latered
    Senior Member burntblacktoast's Avatar
    Mar 2008
    bellflower, il, USA.
    right side carb should work just fine. same jets and all, same choke mechanism.
  1. SL350 VS CB350 Carbs
    By jaguar in forum Technical
    Last Post: 03-11-2011, 12:42 PM
  2. cb350 Carbs
    By kadavenport in forum Wanted
    Last Post: 03-06-2009, 02:25 AM
  3. Wanted: CB350 carbs
    By Jnutz in forum Parts For Sale
    Last Post: 12-01-2008, 06:45 PM
  4. CB350 Carbs??
    By hogsnhondas in forum Wanted
    Last Post: 06-30-2008, 03:06 AM
  5. cb350 stock carbs
    By racerchris46 in forum Wanted
    Last Post: 12-04-2007, 09:50 AM
