Couple of ? about a CB 360
This is a discussion on Couple of ? about a CB 360 within the Technical forums, part of the Caferacer.net Forums category; 1 Can someone confirm for me that the fork tube Dia.on a CB360 are 33mm? I am plan on putting clip ons on it. That ...
Results 1 to 3 of 3
    Cafenut's Avatar
    Jun 2008
    1 Can someone confirm for me that the fork tube Dia.on a CB360 are 33mm? I am plan on putting clip ons on it. That the reason I ask.
    2 Will the top triple clamp for a CB350 fit on the 360? I was going to replace my original one with one made without the bar priches holes.
    Thank you for any information!
    Chris,
    May 2006
    Detroit-ish, MI, USA.
    cb360 tubes are 33mm. cb350 top clamp from '73 disc brake model will fit, but it's the same as the one from your cb360. In fact, the whole front end is the same.
    Older cb350 top clamps will not swap with cb360. You could, however, swap the entire front end, but why? The weakest link in a cb350 is the fork setup.
    May 2006
  1. First couple days below 80°F...
    Last Post: 09-07-2011, 11:17 PM
  2. couple of candidates
    By coreyjdl in forum General
    Last Post: 09-19-2009, 09:35 PM
  3. looking at a couple bikes
    By jmanz6 in forum General
    Last Post: 01-09-2009, 08:34 PM
  4. Couple electrical ?s
    By KeninIowa in forum Technical
    Last Post: 06-30-2007, 07:09 PM
  5. Couple cb engines
    By jreich in forum Parts For Sale
    Last Post: 05-04-2007, 09:13 PM
