question abt kick starter on cb350k
This is a discussion on question abt kick starter on cb350k within the Technical forums, part of the Caferacer.net Forums category; I'm picking up a 1968 cb350k this weekend. the kickstarter will fire up the engine. however, he says it sit's kind of near the riders ...
Results 1 to 6 of 6
    56cbr600rr's Avatar
    Jul 2008
    I'm picking up a 1968 cb350k this weekend. the kickstarter will fire up the engine. however, he says it sit's kind of near the riders peg- this doesn't sound right to me. sounds somewhat broken....
    Is this a big deal???
    bike has low miles, runs fine, good tank, rebuilt carbs, new petcock, no bad rust, all original for $700.
    56cbr600rr's Avatar
    Jul 2008
    looking at the assembly on line, i'm guessing it's the return spring???
    Anyone know?
    Feb 2006
    You can't really know until you see it. If the bike kicks over, the return spring is not broken.
    Many bikes share the same size kicker shaft and someone could have replaced the stock kicker with one from another bike. Happens all the time.
    By the way, a clean '68 350 is a good bike to own.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    if its the return spring, its under the cover and attaches to a lobe on the shaft. there is a boss that it also hooks to on the engine case. i have seen those snap off. it could also conceivably come off, or not be connected correctly. if its anything to the inside of that, you have to pull the motor and split the case.
    May 2006
    Detroit-ish, MI, USA.
    I may be pointing out the obvious, but isn't it possible, since we're talking about a splined shaft, that the PO installed the kicker too low?
    Perhaps a removal & re-install might fix the problem?
    Mar 2002
    , , Turkey.
    sure, could have slipped, but that seems so obvious. but, hey, sometimes obvious is, well, not so obvious!
  1. CB350 Kick Only Starter
    By merivirta in forum Technical
    Last Post: 05-12-2009, 12:43 AM
  2. Intro and CB500T Starter Clutch Question
    By rooter in forum Technical
    Last Post: 04-06-2009, 11:56 PM
  3. Kick Starter
    By Tim in forum General
    Last Post: 03-23-2009, 08:42 AM
  4. Kick starter for CB350
    By JackC in forum Wanted
    Last Post: 07-09-2008, 12:49 AM
  5. CB200 kick starter shaft and starter clutch Q's
    By scott.v in forum Technical
    Last Post: 07-03-2008, 09:04 PM
