Shock Question
Shock Question
This is a discussion on Shock Question within the Technical forums, part of the Caferacer.net Forums category; Is there a company that sells a kit to convert an " Eye to Eye " rear shock to an " Eye to Clevis " ...
Results 1 to 10 of 16
Thread: Shock Question
    Senior Member Wanker's Avatar
    Aug 2008
    Montague, NJ, United Arab Emirates.
    Shock Question
    Is there a company that sells a kit to convert an " Eye to Eye " rear shock to an " Eye to Clevis " shock ? I thought Z1 Enterprises did but couldn't find it .
    If they call a sheep a ram.
    And a donkey an ass.
    Why do they call a ram in the ass a goose?
    Nov 2008
    Your Moms House, USA
    Never heard of an 'adapter' or anything. Wouldn't feel safe with one if there was, it'd be a link, a thing that could possibly move, which would not be good for handling or safety.
    I've seen people grind off the 'eye' bracket on the swingarm and weld up a new mounting system, but hell, I'd rather just buy a set of shocks that work properly. What shocks are you trying to mount to what bike?
    Aug 2008
    I was considering using a set of Red Wings on my CB750 but since the CB is obviously Eye To Clevis and the RedWings only come Eye to Eye I'd get an adapter to fit them . I remember seeing them through Z1 Enterprises if I'm not mistaken . Chances are though it probably wouldn't be a bright idea as you said .
    Senior Member trepanned23's Avatar
    May 2008
    EAST! Hollywood, 90004
    I made up a set of clevis' to eye's adapter out of aluminum on a CNC machine. Didn't work because the height of the adapter to get clearance between the eye radius/bolt centerline, and the clevis bung (bushing) made the part too flexible. As well, the shock angle was moved too much on a forward slant. Too get a better mental picture, the part looked like a lower case "h" - The bike's rear end felt horribly unstable on the long sweepers especially. I finally just bought a set of MDI's (13 3/16 eye to clevis) 400 # from Old Bike Barn for 168.00 and they, although not great shocks by any stretch, are MUCH BETTER than stock.
    Nov 2008
    Wanker, I have HD Progressive shocks on my CB750. They are really quite nice, and not terribly expensive. You wont have to weld anything, and wont have to deal with flexible/shitty-geometry of some kind of adapter.
    Feb 2006
    looky here;
    http://omarsdtr.com/shox3.html
    or you mean hammerheads?
    Nov 2008
    Or far better, 160 bucks, + another 70 for springs. http://www.z1enterprises.com/detail.aspx?ID=523
    More than twice as much, but worth it.
    Senior Member pampadori's Avatar
    May 2007
    Richmond, Va., USA.
    i'm using these...
    they are a good bit stiffer then stock and can be made stiffer yet with the preload adjustment. They can be filled with N2 or air to various pressures for dampening and rebound adjustment. Seemed machined very well and are pretty cheap too. they are sold on ebay all the time.
    the only thing i have negative to say about them is that your money doesn't put food on an American's table. To punish myself for this, i only "fed the ducks" while watching softcore for 1 full month.
    http://www.slingshotcycles.com
    Stainless braided brake lines and other odds and ends.
    Enter coupon code "caferacer" during checkout for 15% off
    Junior Member dshadler's Avatar
    Apr 2012
    Pine Grove, PA, USA.
    What kind of shocks are they? I can find them anywhere.
    Apr 2012
  1. rear shock question
    By ukTony in forum Technical
    Last Post: 01-19-2012, 12:54 PM
  2. Paging CrazyPJ with a Chinese shock question
    By Geeto67 in forum General
    Last Post: 01-08-2012, 01:55 PM
  3. Honda Shock Question
    By john2007 in forum Technical
    Last Post: 03-03-2011, 01:47 PM
  4. Shock Mounts
    By oldTS in forum Technical
    Last Post: 04-04-2010, 04:55 PM
  5. making your own frame - shock question
    Last Post: 03-01-2010, 11:25 AM
16 eye to clevis shocks
clevis to clevis shocks
clevis to eye shock adapters
eye to clevis adpated
honda clevis shock adapters
nicetect
nicetect shocks
rfy motorcycle shock absorber
rfy shocks
