oh mah god, aaron
oh mah god, aaron
This is a discussion on oh mah god, aaron within the Technical forums, part of the Caferacer.net Forums category; dude, i cant tell whether i should thank you or kill you. after our discussion about the front end, you said you turned it etc...i ...
Results 1 to 6 of 6
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    oh mah god, aaron
    dude, i cant tell whether i should thank you or kill you. after our discussion about the front end, you said you turned it etc...i started to worry about the top bearing surface of the stem. my machinest hadnt done anything to it as of friday. i told him no big deal and id swing by early in the week. i went over there this a.m. to check on the the top of the stem. it looked ok but i really had no idea about the measurements. so with bearings in hand i went in and we began to measure things up. apparently, the top bearing surface of the stem is too small by .002. remember taking a file to it??? he claims too small for the bearing. so basically what i have here is useless to me. he claims he can dimple the stem and get it to work, but now im getting into some more $$$ and why not just get another? so, my quest continues. im either going to grind, press and fit another, or, just get another bottom. the problem with getting a new bottom is that if the offset is just 1 degree different, it wont work. (ive been through this with the 350 and 360.) so, i just wanted to say thanks, for nothin!
    just kidding. i have a 450 front end that might work. i'll keep you posted.
    later
    j
    Senior Member aaron's Avatar
    Mar 2002
    Melrose, MA, USA.
    Just change the stem.
    JD
    JD is offline
    Senior Member JD's Avatar
    Mar 2002
    NY
    you should be able to find those trees about anywhere. I think that must be the most common backyard junker around. hell I think they even come in the happy meals now
    Mar 2002
    Melrose, MA, USA.
    Omaha Joe,
    I know I screwed you up in the beginning, but what I don't understand is why you just don't get a stock stem and change it. Maybe you guys do things different in Oh mah a.
    Aaron
    Mar 2002
    , , Turkey.
    some examples of prices i have found here.
    cb 750 trees. usable.
    75 bucks and an hour and half drive one way
    motorcycle junk yard in dover, delaware, the place that advertises on ebay all of the time.
    cb350/2 motor. no guarantee. buy it, if there is anything other than water and dirt inside, youre lucky. and no, you cant look at it first
    100 bucks
    baltimore cycle salvage
    30 mins away
    this is why i dont just go buy things. they suck down here and i am out of the motorcycle loop. although i have been offered a biker friendly job at a place that a certain other "daytona speed bump" works with another certain 350 honda lwsv racer works. i'll be there before late spring working hopefully and getting my share of spares. you have to realize also, if youre not riding a banshee or a cr125 around here, people for the most part dont know what the hell you are riding. i commented once that when i pulled up to the local motorcycle shop, and there is only one big one here, on my cl350, they looked at me like i was pulling up in a spaceship. i feel outta plca since my truck isnt jacked up or lowered down. i like the way my truck rides. so shoot me.
    and dont you mean aromaha??
    signed
    slo joe from idaho
    Mar 2002
    , , Turkey.
    let the carnage begin.
    i began step one of the stem tube grafting operation tonight. i removed the doner stem from the corpse and have it isolated for the time being. i am hoping to have the transplant completed late this week. pray it doesnt reject it.
    joe c
  1. Aaron
    By Chikor in forum General
    Last Post: 07-11-2005, 04:32 PM
  2. hey aaron,
    By imslow in forum General
    Last Post: 08-25-2004, 01:28 PM
  3. Aaron and JD
    By Donald in forum General
    Last Post: 07-19-2004, 10:51 PM
  4. Aaron...
    Last Post: 07-07-2004, 09:02 AM
  5. Aaron's oil
    By imslow in forum Technical
    Last Post: 06-25-2004, 04:32 PM
