Cam assembly issue - Page 3
Cam assembly issue
This is a discussion on Cam assembly issue within the Technical forums, part of the Caferacer.net Forums category; Yeah, I tension my johnson rod every chance I get...you crazy bastard. I did as Joe said...and it worked! As you can see, I started ...
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Senior Member Pete Casper's Avatar
    Oct 2006
    Schenectady, NY, USA.
    I did as Joe said...and it worked! As you can see, I started this post at midnight the other day... Having a fresh mind went a long way....
  2. #22
    Fairfax, VA, USA.
    I was faced with the same puzzle today. One side would go on okay, the other was impossible. Then I found that I could rotate the crankshaft (and hence the camshaft) just so to get both sides to fit. Unfortunately, when I finally got everything together, I discovered the exhaust valves hit the pistons so I got to take a break to clear my head so I can figure things out. It could be the cam gear is off one tooth. Or perhaps it's 180° off. I dunno. Someone hand me a beer, I'm done for the night.
  1. Need new throttle assembly, suggestions?
    By shinneh in forum Technical
    Last Post: 07-20-2010, 10:55 AM
  2. Let the re-assembly begin
    By tonupoakland in forum General
    Last Post: 09-25-2009, 05:12 PM
  3. Front Shock Dis-assembly
    By mitchellsk in forum Technical
    Last Post: 11-10-2008, 01:08 PM
  4. honda 350 motor assembly
    By snorkelfork in forum Technical
    Last Post: 01-14-2008, 12:12 AM
  5. Throttle assembly
    By ascentofstan2 in forum General
    Last Post: 02-26-2007, 11:55 PM
