fiberglass sidecovers
This is a discussion on fiberglass sidecovers within the Technical forums, part of the Caferacer.net Forums category; so im finally getting around to making some permanent sidecovers for my bike in preparation for the new paint job im gonna do. so after ...
Results 1 to 4 of 4
    Feb 2009
    austin, texas, .
    so after i track down a good chunk of foam to cut into and shape... do i lay out the epoxy mixture stuff over that shape or do i make a mold?
    also, since im not making a gas tank or anything load bearing i guess i wont need too great of a product... any info on a cheaper fiberglass kit?
    i searched on here but only found a link to dotheton.
    honk if youre horny.
    Member shortshift's Avatar
    Sep 2007
    Oakland, CA, USA.
    you could use polyester resins; they're usually cheaper than the epoxies. they're also a lot more aromatic so make sure you have plenty of open space and circulation. It's hard to do this stuff on the cheap, tho. you got all your chemicals, the glass, foam, tools, eye protection, gloves, sand paper, filler...then the freakin' paint...
    I'd poke around the boating forums for applicable techniques. there are probably a lot of articles on auto body work that would be directly transferable, too. I spent a lot of time looking through issues of epoxy works. but there's lots of good printed reading material out there, too.
    better is the enemy of good enough.
    Aug 2006
    Portland, Oregon, USA.
    It's still a good idea to use good materials.
    If you've got the old side covers you can make a plaster female mold and then wax that before laying your pieces up. If you're using a male mold you'll be in for a lot more finish work just to get the parts smooth enough to paint. It'll take a bit more time but a well prep'd female mold will make your life easier in the long run.
    ~Albert Einstein
    Feb 2009
    austin, texas, .
    alright... plaster mold first for sure. recommendations on who to purchase it from?
  1. New CB750 body sidecovers
    By frankenbike in forum Parts For Sale
    Last Post: 09-01-2010, 10:07 PM
  2. kz400 sidecovers for sale
    By txchainsawgogi in forum Parts For Sale
    Last Post: 07-15-2009, 12:19 PM
  3. sidecovers for cb160
    By ROSKO in forum Wanted
    Last Post: 05-16-2008, 03:38 AM
  4. 4 Honda CB350 sidecovers!
    By UngaWunga in forum Parts For Sale
    Last Post: 01-10-2007, 09:34 PM
  5. 1970s Honda CB350 sidecovers
    Last Post: 04-12-2005, 04:11 PM
