Carb Issues? Please help!
This is a discussion on Carb Issues? Please help! within the Technical forums, part of the Caferacer.net Forums category; I know this is a heavily covered issue but I dont have much access to the internet right and was hoping for an answer by ...
Results 1 to 10 of 15
    Senior Member ZouLou's Avatar
    Aug 2007
    St. Louis or Columbia, Missouri, USA.
    I know this is a heavily covered issue but I dont have much access to the internet right and was hoping for an answer by tomorrow. It is on a '77 XS650 (my dad's bike). It had an issue and was draining gas out of what looked to be the float bowl so I swapped his carbs out for my old ones ('79 XS650) today and took it for a spin. It seem to work great. I then let him go for a ride but he accidently kicked it into 1st from neutral without the clutch and killed it (he was pretty excited and just didnt realize he didnt have the clutch in haha). When we tried to get it started again it was draining gas through the air filter. What could cause this? I mean it ran parfect for me then killed it then carb is free flowing? I mean this may have been the problem before as when I removed the filters to replace the carbs there was some gas in them as well. Any help would be awesome. Thanks a lot guys.
    1979 Yamaha XS650 Special
    https://www.caferacer.net/forum/topic.asp?TOPIC_ID=12991
    buckandaquarter's Avatar
    Sep 2008
    Stuck float or a piece of trash in the float needle.
    Sep 2008
    Aug 2007
    Could that be caused by killing it? Also opened up the old carbs and the floats weren't stuck at all.
    Aug 2007
    Sep 2008
    Nope. They will only flood if the float needles don't seat properly. Do you know how to st them up?
    Sep 2008
    Aug 2007
    Yea I actually just rebuilt the carbs and replaced the float needles is there anything special about putting them in I need to know?
    Aug 2007
    Feb 2009
    austin, texas, .
    the drain tubes could be severely corroded... i think its what theyre called...the protrusions on the bowls that go up into the carb body. that or the float needles.
    sometimes the rubber gaskets the needles seat into are shot.
    gas is so thin that it seeps out of even the tiniest gap.
    honk if youre horny.
  1. 82 CB900F Carb issues
    By EofA in forum Technical
    Last Post: 04-22-2012, 09:32 PM
  2. 1973 CB350F Carb Issues...Please Help!!
    By nkazazian in forum Technical
    Last Post: 06-21-2011, 12:29 AM
  3. 78 cb 750 carb/fuel issues
    By skife in forum Technical
    Last Post: 07-28-2010, 01:09 AM
  4. cl175 build - carb issues
    By nixoid in forum Technical
    Last Post: 03-26-2008, 11:50 PM
  5. CL175K6 carb issues
    By midnight08 in forum Technical
    Last Post: 03-10-2008, 08:41 AM
