Shorter brake cables for my CB360?
This is a discussion on Shorter brake cables for my CB360? within the Technical forums, part of the Caferacer.net Forums category; Can you buy a shorter front brake cable for the CB360? I like the look of just the raw bike with no front fender, especially ...
Results 1 to 10 of 17
    360Cafe's Avatar
    Feb 2009
    Can you buy a shorter front brake cable for the CB360? I like the look of just the raw bike with no front fender, especially since I'm cheap and don't want to have mine re-chromed. The problem is since I have a drag bar on it now and eventually I may put clubmans on it so I have alot of slack and it runs right across my fender. I was looking to take some of that slack out so I can run it up the fork. Any other sugestions would be helpful too.
    Thanks
    Senior Member whiskeysid's Avatar
    Mar 2008
    Champaign, IL, USA.
    Motion Pro will custom make cables to your specs. It's not cheap, but it's top quality stuff. Cables can be shortened at home using a solder pot (do a search on this forum), but I wouldn't recommend it for a brake cable that your life may depend on. But there are those of us who laugh at danger (myself included)! Just so we're talking about the same thing, though, doesn't a CB360 have a front hydraulic disc brake? If so, you'd need a shorter brake hose, not cable. If a hose is what you need, disregard my above comments. I know little about hydraulic brakes because I don't like them one bit. FIY, my daily rider has no front fender, and life sucks when you ride it in the rain.
    -the Rad Baron
    -\'72 CB350
    -\'72 Kawasaki H1
    -\'72 Yamaha R5/RD350 hybrid
    -\'77 XS650
    -\'47 Harley U flathead
    -a bunch of other old Jap bikes
    Member tomfarr's Avatar
    Mar 2009
    , Indiana, USA.
    My '75 CL360 (my first bike in '76) had a front drum, so some of the early CB360s may have, as well.
    I have made my own throttle cables, it was a PIA, but I got what I needed.
    I would have to agree with whiskeysid, though. For a brake cable I would want it made by someone that does it everyday.
    BMW had drum front brakes for a long time, many of which were intended for low bars (Europe, you know...). Depending on your nipple needs, you might find something in their inventory.
    \'74 Honda CB200
    \'79 BMW R65
    Senior Member cafe350's Avatar
    Mar 2009
    Columbus, OH, Djibouti.
    If you're looking for disc brake lines, try sling shot cycles for steel braided lines specifically for low bars.
    \"Hey, McCloud! Get off of my ewe!\"
    Trevor,
    \'72 Honda cl350 (sold)
    \'80 gs450E, the \"spooky \'Zuki\"
    \'04 Kawasaki Ninja 500
    Jun 2008
    Medford, Oregon, USA.
    I'm in the same situation. I'll have to give Motion Pro a jingle since I'm using different levers that have smaller adjustment barrels then the stock ones and the cable won't fit into it.
    360Cafe's Avatar
    Feb 2009
    Yea it is actually a line, not sure why I said cable. I may give that sling shot cycles or Motion Pro a call. My daily rider has a front fender, this is just a fun project.
    , Decrepit and Decomposing, .
    reuseable swivels for JIC fittings 5 bucks
    ptfe stainless braided hose 5 bucks a foot
    two JIC banjos 5 bucks
    build your own dude
    cable or hose it's nothing but a thing
    Mar 2009
    , Indiana, USA.
    You can have custom brake hoses made up in any major city.
    \'74 Honda CB200
    \'79 BMW R65
    Senior Member ZouLou's Avatar
    Aug 2007
    St. Louis or Columbia, Missouri, USA.
    Also check out the members products forum pampadori makes custom braided brake lines for a really reasonable price.
    1979 Yamaha XS650 Special
    https://www.caferacer.net/forum/topic.asp?TOPIC_ID=12991
    have any of you guys actually tried a re-useable swivel fitting?
    it's easier than double flaring your own steel brake line and the beautiful thing is, unlike a custom made hose with swedged on ends
    if you make it too long
    you can simply cut it shorter and screw it back together again
    they are good for 3000 psi
    ptfe= teflon lined stainless braided hose
    easier than connecting the dots in a kids coloring book
    aeroquip makes the nicest ones but they will cost about 10 bucks where the cheaper ones are 5
    you need number 3 size hose and fittings
  1. What to do with brake lines, cables, w/ clip ons?
    By xjoey dubsx in forum Technical
    Last Post: 06-10-2012, 11:19 PM
  2. Shorter Cables
    By bronco652 in forum General
    Last Post: 03-27-2011, 12:46 PM
  3. cb360 throttle cables
    By Johnny Gaijin in forum Technical
    Last Post: 09-23-2009, 10:37 PM
  4. Shorter cables
    By JerryRice in forum Technical
    Last Post: 08-19-2008, 09:58 AM
  5. DIY shortening brake/throttle cables
    By mudmonkey in forum Technical
    Last Post: 03-16-2008, 10:40 AM
brake cables for cb360
cb350 brake cable too long
cb350 cafe cable front brake
cb360 brake hoses
cb360 front brake cable
cl 360 brake cable
honda cb360 front brake cable
honda cb360t brake hoses
shortened front brake cable
