cb350 swing arm torque spec
This is a discussion on cb350 swing arm torque spec within the Technical forums, part of the Caferacer.net Forums category; my factory manual doesn't have the info, can anybody let me know what to tighten it to?...
Results 1 to 5 of 5
    Senior Member 736cafe's Avatar
    Dec 2005
    chicago, il, .
    scott from chicago
    (ahrma 527)
    Rocan's Avatar
    Apr 2009
    *checks clymer manual*
    odd... it doesnt say...
    I would just tighten it down until its snug, and then check it every so often to see if it loosens
    Member CBRider's Avatar
    Feb 2007
    Placerville, CA, USA.
    The factory manual (at least the one I have) has it on p.130. Terminology might be the problem. They call it the "Rear fork pivot bolt". Torque specs are 550-700 kg.cm. That is 40-51 ft.lbs. for us.[8D]
    Rocan's Avatar
    Apr 2009
    odd....
    clymer manual calls it the "swinging arm"
    Dec 2005
    chicago, il, .
    cool thanks
    scott from chicago
    (ahrma 527)
  1. Single shock swing arm for CB350....?
    By jringo in forum Technical
    Last Post: 08-16-2011, 11:09 PM
  2. Reworking CB350 Swing Arm Support[Another Q?]
    By boomshakalaka in forum Technical
    Last Post: 11-16-2009, 01:58 PM
  3. CB350 Crank Journal Torque
    By hysteria411 in forum Technical
    Last Post: 05-19-2008, 12:42 AM
  4. shocks/swing arm for a cb350
    By Eric750 in forum General
    Last Post: 04-10-2006, 06:51 AM
  5. FR- Torque spec fer tor, SON!
    By ROSKO in forum Technical
    Last Post: 12-20-2005, 11:07 PM
cb 350 swingarm torque specs
cb350 swingarm spec
cb350 swingarm tightening
cl350 swing arm torque
honda cb360 swong arm torque
swingarm torque cb350
tourque specs cb350 swingarm
