thoughts on these...
This is a discussion on thoughts on these... within the Technical forums, part of the Caferacer.net Forums category; I snagged these on ebay...any thoughts... they are slightly longer than my stock rear shocks so i hope to get a little more ground clearance ...
Results 1 to 7 of 7
    Senior Member raven's Avatar
    Jan 2009
    milledgeville, ga, USA.
    I snagged these on ebay...any thoughts... they are slightly longer than my stock rear shocks so i hope to get a little more ground clearance (my front forks are slightly longer too, I got them slid up in the triples to arrive at stock ride height in front).
    Any thoughts? Complete junk? Rebuildable? Any clue what they came on?
    Bike:
    Buell X1
    Honda S90 (box of parts)
    Honda CB750C (runs)
    Those look like the stockers of a CB900f. They should raise the rear end, but I am not sure how much they will improve the rear wheel control. They are the Honda FVQ shocks which I think stood for Fade Very Quickly.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Jan 2009
    Anything is better than what i got now...stock 750c rears with frozen preload adjusters and an exxon valdez size leak in one :-D
    Anything to be done to make em work any better?
    Bike:
    Buell X1
    Honda CB750C (runs)
    Senior Member Rocan's Avatar
    Apr 2009
    Brooklyn, New York, USA.
    why not spend the cash and just get progressive springs?
    Jan 2009
    I will eventually but funds are tight right now. (insert violin playing smiley here) Its a choice between these, cheap chinese units, my ratty originals or no bike this summer. If there is anything I can do to make them work better while I have them off I will do it, otherwise I will put them on and run as is.
    Bike:
    Buell X1
    Honda CB750C (runs)
    Senior Member Wanker's Avatar
    Aug 2008
    Montague, NJ, United Arab Emirates.
    Great shocks . A CB900F upgrade I think . Only bad thing's that they're not rebuildable . CycleXchange has brand new 13" Progressives for 139$ . I nabbed a set . Great shocks .
    If they call a sheep a ram.
    And a donkey an ass.
    Why do they call a ram in the ass a goose?
    Stock (not optional) CB900f shocks (and some 1100F models also). These were a back in the day upgrade to SOHC cb750s since the stockers were pretty shitty. But that is when they were new, now a days who knows what 20 years of use and abuse has done to them.
    Put them on, they are better than what you have (leaking huh? yeah that is shot). The only improvement you can make is to put new rubber bushings in the bolt areas (swingarm and the top of the shock). I think they may have been made by Showa originally for Honda.
    There is a switch at the bottom of them that should allow you to adjust valving - for 1982 these were some space age shit!
  1. Thoughts
    Last Post: 08-21-2010, 04:18 PM
  2. thoughts on these shocks?
    By BoXcArStRiPeS in forum Technical
    Last Post: 01-20-2010, 02:46 PM
  3. thoughts on KZ650s?
    By borzwazie in forum General
    Last Post: 01-03-2010, 01:35 PM
  4. 92 VFR750 thoughts?
    By Swagger in forum General
    Last Post: 12-28-2009, 06:57 PM
  5. thoughts on R65
    By pampadori in forum General
    Last Post: 12-19-2008, 10:22 AM
