Rear End Drifting
Rear End Drifting
This is a discussion on Rear End Drifting within the Technical forums, part of the Caferacer.net Forums category; Ok, So last night, riding my bike up the pch I noticed the rear end of my bike "drifting" towards the left. It was an ...
Results 1 to 10 of 17
    Member indefinite's Avatar
    Dec 2008
    encinitas, ca, USA.
    Rear End Drifting
    Ok,
    So last night, riding my bike up the pch I noticed the rear end of my bike "drifting" towards the left. It was an ackward feeling like it was about to break out from underneath me. I checked the rear axle, it is aligned (based off the marks on the Rear Dropouts). THe Front end is good, bolts, etc in check. The rear shocks are new Hagons and are bolted tight. Anyone have any idea of what this might be? Rear Airpressure? Any input I would be super grateful!
    Thanks
    Senior Member mitchellsk's Avatar
    Sep 2008
    memphis, tn, USA.
    Swingarm bushings in good shape?
    mitchellsk
    1970 CB350
    1975 CB360
    1975 400f
    1973 450
    1975 750
    \"I like to hold the microphone cord like this, I pinch it together, then I let it go, then you hear a whole bunch of jokes at once.\" - Mitch Hedburg
    Mar 2004
    Raymond, NH, USA.
    wtf bike is it? It could be a zillion things.
    Steerhead bearings
    swingarm bushings
    bent frame
    axle not aligned (those marks aren't accurate)
    wheel bearings
    Alignment of the moon and Jupiter
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    sounds like tire pressure...
    weak ass side walls?
    how old are your tires?
    could be bushings.
    iphone generated fag
    Dec 2008
    encinitas, ca, USA.
    Sorry,
    It is a cb 350 (1971) Tires are still new. The steerhead bearings have not been replaced, nor the swingarm bushings. The so called "drift" happens around 30-45 mph.
    I am going to start with the air pressure then work my way down the list.
    Thanks guys
    May 2006
    Detroit-ish, MI, USA.
    quote:sounds like tire pressure...
    +1
    Palmyra, NY, USA.
    I would put the bike up on a center stand and spin the rear tire while checking the alignment with the spin and the alignment to the front end. Sounds like either the rear is bent (rim or swing arm) and/or the rear tire is not aligned with the front tire.
    Bob - Palmyra NY
    2 - 69 CB750, 1 Turbo
    1 - 71 CB750
    , Decrepit and Decomposing, .
    new tires and you are counting on the alignment marks that weren't accurate when the bike was new to determine your rear axle is adjusted correctly
    hold your hands out while I splinter a ruler across them
    heck, most of the time when I actually have one here in person that has the same "complaint"
    I can simply sight down the chain and see the problem
    it ain't rocket science and installing new tires doesn't bend, break, or wear anything that wasn't already
    May 2006
    Hack, Are you a nun?
    I agree with everything you just said, but check tire pressure first. I have to admit I am a bad example, and don't check mine often enough. Whenever the back end gets squirrelly on me, low tire pressure is usually the culprit.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    there is somethng very wrong. make sure you look at everything. this sounds like it could end in a big scraping sound.
  1. Rear Wheel
    By RondaDAHonda in forum Technical
    Last Post: 06-25-2012, 08:48 PM
  2. Swapping rear rim?
    By smahala1286 in forum Technical
    Last Post: 06-03-2009, 04:33 PM
  3. Rear spacer? rear axle? what do you guys think?
    By midnight08 in forum Technical
    Last Post: 03-29-2009, 03:01 PM
  4. drifting piston ring?
    By McB in forum Technical
    Last Post: 04-25-2007, 08:04 PM
  5. rear hub
    By Eric750 in forum General
    Last Post: 02-05-2006, 07:22 PM
