changing fork seals!
This is a discussion on changing fork seals! within the Technical forums, part of the Caferacer.net Forums category; ive never done this before and could use some help in this field. its on a honda cm400. will i have to take the lower ...
Results 1 to 2 of 2
    Feb 2009
    austin, texas, .
    will i have to take the lower leg off the upper or what?
    honk if youre horny.
    Jul 2006
    New Castle, PA, USA.
    yes, the fork will need to come apart. trust me, don't try it any other way until you know how they fit together.
    the bolts in the bottom of the fork legs may stick and not want to come out of the fork tubes - after you pull the springs, push a broom handle down the tubes to keep the piston from spinning when you remove the bolt. see my build thread for how to build a seal removal tool.
    "This site is bullshit."
  1. Changing fork oil
    By mickey356 in forum Technical
    Last Post: 07-11-2012, 08:51 PM
  2. changing fork seals on cb750???
    By jeddy in forum Technical
    Last Post: 04-11-2011, 10:29 AM
  3. promoly fork seals
    Last Post: 04-06-2008, 02:13 PM
  4. Fork Seals
    By Pete Casper in forum Technical
    Last Post: 09-26-2007, 09:03 PM
  5. Fork Seals
    By gte619n in forum Technical
    Last Post: 05-23-2006, 01:36 AM
